Old 03-25-2012, 11:56 AM   #11
camper_Lucy's Avatar
If he has a GVWR of 7300 then he has the 5.4L 4x4 and that has a hitch load of 800lbs, so he is in spec for the TV but on the high end. I would lean towards the integrated sway control system myself on this setup.
However, if I had the Curt I might try adding two friction bars knowing I was risking 150.00 and that the back up plan would be to move to an integrated system if I did not like the setup.
Keep in mind that you do have to drop the bars to maneuver the TT in tight spots or backup, something that you do not have to deal with on an integrated system like the equalizer.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 03-25-2012, 12:14 PM   #12
When I weighed it I had all the kids in the Expedition. We'll have a few other items, like the Nintendos for the kids to play with but I'm not planning on loading anything else in it. The Expedition is a 5.4L v8 and has a new transmission ( not sure on the ratio but I know we had them rebuild it with the heavy duty components ). Not sure where to go to get the dual friction sway bars. I'm assuming they need to be from Curt to match the WDS so I'll check their website. Glad to see someone else pulling with the same system I'm looking to use!
aveytua is offline   Reply With Quote
Old 03-25-2012, 12:34 PM   #13
punkaccountant's Avatar
I owned a 30 ft. Jayco which was pulled by an F-150 with the Curt WD hitch. I ended up switching to an Equal-i-zer and the difference was night and day. Here's my take on your situation. I feel you are maxed out on the towing capabilities of your Expy. If you are financing, why not just include the new hitch in the amount you finance. Over 120 months it will be around $6/mo. Over 60 months it would be $11. Family safety should be of your highest priority. Why take chances to save a few bucks?
punkaccountant is offline   Reply With Quote
Old 03-25-2012, 12:42 PM   #14
If I switch from the Curt to the Equal-i-zer what model would you recommend? I've heard about the Equal-i-zer but don't know much about them.
Old 03-25-2012, 12:54 PM   #15
Triguy's Avatar
1,000/10,000 Equal-i-zer 4 point. Not the e2. RVW is cheapest to buy from.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-25-2012, 01:08 PM   #16
steeleshark2's Avatar
Get 2 of these if you keep your Curt hitch:
Amazon.com: Curt Manufacturing 17200 Sway Control Kit: Automotive
steeleshark2 is offline   Reply With Quote
Old 03-25-2012, 01:50 PM   #17
RoadDog66's Avatar
Aveytua,
Was just at RVW and they said they are moving away from the Equalizer and to a new type called Blue Ox. They said the Blue Ox has a better paint (specail powder coat) that will last longer. It uses heavy chains to adjust the sway bars instead of resting it on an L-bracket like the Equalizer does. It looks nice (lite gold color). Said it was only $10 more in price. I still went with the Equalizer 1000/10000 since I had studied up on it and it appears to be proven and reliable plus I wasn't a fan of the chains. I think the new Blue Ox would work fine too though if you chose to buy a whole new setup. Congrats on the new trailer.
TV: '15 Ram 6.4 Hemi CC 4x4
Old TT: '12 Rockwood Roo 19 (sold)
New TT: '14 CR Sunset Trail 290QB
WD: Equalizer 1200/12K
BC: Ram OEM
RoadDog66 is offline   Reply With Quote
Old 03-25-2012, 02:07 PM   #18
Triguy's Avatar
Blue Ox is nice, too, from what I've read.
Scott
2012 Shamrock 233S
Old 03-25-2012, 08:42 PM   #19
Thanks everyone for the feedback...and the link to what I need to buy for the Curt WDH.
Old 03-25-2012, 09:00 PM   #20
No problem! Let us know what you finally decide on.
