04-25-2018, 09:14 PM
Is an inch worth it
From time to time my truck and 5er chuck I have noticed that the dealer installed b&w is about 6 “ behind axle looks like I can move hitch up 2” max. My question is would there be a noticeable difference or advantage. For that small of a move I read optimum position in over axle
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
04-26-2018, 02:41 PM
What is your tow vehicle?
6" behind the axle is pretty far. It should be directly over the axle. I'd move it the 2" forward if you can, but that won't do anything for the 'chucking'. Now if you're bouncing and not really chucking, then moving the hitch forward may help that a little.
Gotta go campin!
04-26-2018, 02:48 PM
Send us a picture of your truck and hitch setup so we can better see your situation.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
04-26-2018, 02:56 PM
What is 6" behind the axle?
The hitch pin connection or some other part of the hitch?
As mentioned, pictures of your set-up would help.
Most installations call for the hitch pin to be directly over the axle, to 2" ahead of the axle.
Post your tow vehicle and R/V specs too.
I see no signature and nothing in your profile telling us what you have.
Always good to provide as much information as possible when asking for help.
04-26-2018, 10:45 PM
Your all correct I should have sent a picture and I would love to update my signature page but I have followed the instructions and not all the options appear to work so missing a step or can’t follow instructions both are possible it’s dark out but I got pic
04-26-2018, 10:50 PM
It’s a 2016 f 350 xlt long bed 4x4 pulling Wildcat 383mb 12k but truck and trl weighs 23900 ish usually a smooth ride but hit the wrong road and lots of jerking going on
04-27-2018, 09:08 AM
Your all correct I should have sent a picture and I would love to update my signature page but I have followed the instructions and not all the options appear to work so missing a step or can’t follow instructions both are possible it’s dark out but I got pic Attachment 169645
I don't own a B&W so maybe those who do will chime in. Something doesn't look correct with the orientation of the hitch/arms/plate. Is one of the components installed backwards? See how the plate attaching arms lean towards the FRONT of the truck in the photos below.... yours go rearward???
Again, I don't own one but something is awfully odd about yours.
Does it have a slide option? Is it in the rearward slide position?
See images below...
04-27-2018, 03:16 PM
I agree based on those pictures I am a little different the hitch and installation of hitch came as part of the trl deal had the gooseneck installed at an accessory store but the companion was assembled and placed in the truck by rv dealership guess before my next trip need to find instructions and switch it up if it needs it thanks
04-27-2018, 03:44 PM
B&W has adjustment within where it is mounted to the truck. You can adjust 3 inches up or down within the mounting and move it forward or back 6 inches within the mount.
Hope this helps...
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
04-27-2018, 03:59 PM
2007 WildCat 32QBBS
Your upright arms are either backwards or need to be moved forward, or BOTH.
Ideally the pin should be 2" in front of the axle tube's centerline on your 8' bed truck. This properly distributes some weight to the front axle for a smoother ride.
04-27-2018, 04:35 PM
X2with 5 picker Imoved my hitch forward of the axle from behind and stoped the chucking
04-27-2018, 09:20 PM
Thanks for the input guess I will be moving them and flipping them I was just wondering if that inch or two would be worth it not that “ professionals” would put the arms backwards but after seeing pics and then YouTube videos and instructions posted here I do
04-27-2018, 10:29 PM
Jack of All Trades
I had the exact hitch.
On my setup, the hold down bolt on the base was to the back end the truck, not to the front as in your photo. The head arms were also were closer to the front end of the truck than to back of the end of the truck. This setup was based on the installation instruction.
I think if you were to remove the head, turn the base 180* around, then put the head back on, I think that the kingpin will then be atop the axle to 2” in front of the axle as it should.
The manuals for the hitch can be found here:
http://www.bwtrailerhitches.com/site...010%202017.pdf
http://www.bwtrailerhitches.com/site...nual%20WEB.pdf
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
04-27-2018, 10:36 PM
I thought about that haven’t gotten the instructions out yet but in either the E trailer video or the other video also from a reputable source they said the warning sticker and hold down bolt went to the front second video said for the new dodge hold down bolt to the back
04-28-2018, 06:43 AM
Maybe it's me or the picture but the hitch head doesn't look square to frame?
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
04-28-2018, 07:49 PM
Had some spare time while sun was still out so I took twenty minutes flipped arms and moved up one hole. Didn’t have trl but height I believe was good but I will check now that I know dealership just threw together I felt like I always had more than enough room when turning or backing but I will be aware of that as well here are the before and after again thank you according to the chart provided I guess I got about 4 inches at a minimum
04-29-2018, 01:59 PM
2007 WildCat 32QBBS
You're getting closer but it looks like you need to put it forward more, like one of the previous posted pics.
04-29-2018, 10:29 PM
Ok I was going to say that wasn’t an option no more holes left which is true but I know I saw in a video that the “ receiver” has to be flipped but video mentions only dodge as well as another set of instructions I found on line while the 2013 dodge was only truck referenced I guess it didn’t say other trucks as well found a article for 2015 they also put in same position as what I assume mine is in reading the other instructions added a reverence to the position 2 in the above referenced chart. So now I guess if position two is possible I would feel the need to measure as I would lose 8 inches of clearance between cab and cap plus between the back of bed and trl From where I started knew I had plenty of room moving up 4 inches going out in two weeks I will see how she does ( she normally does real well only seemed to be certain roads or conditions with the chucking ) under last set up. I will also measure the clearance in current setting and see if I am comfortable moving up more more I guess I could split difference and towards the cab only 2 inches. Thank you for noticing if I find time I might call B&W.
05-09-2018, 03:17 PM
Is an inch worth it
I hooked up today I didn’t measure tried to get inspected and tanks dumped before we head to air show in Abilene this weekend. Definitely gonna need to measure appear to be plenty of room between cab and cap but worried about the bumper and 5th wheel if I move to position 2 moving head up 3 more inches
05-11-2018, 10:15 PM
I measured I can move up more but talking fractions of inch of clearance between bumper and trl so I will stay where I am at. I also discovered the hard way that moving up 3 inches made pigtail too short pulled out receptacle on truck and pulled black cover off of wire near where connected on 5th wheel finish patching to get me home tomorrow
