Old 06-29-2016, 08:37 AM   #11
SeaDog's Avatar
There is wiggle room built into the max weights a MFG lists for their vehicle. You have gauges for the trans and as long as you are not hearing clunking from the reared or Ujoints I wouldn't worry about it. I would make sure my tires are up to the task and properly inflated. JMHO
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-29-2016, 11:41 AM   #12
Dodge Guy's Avatar
And as I said, some manuf have different GCWR with nothing more than different gears! So as long as your under axle weights without being crazy, such as trying to tow a 10klb trailer 500 over is OK by me.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-29-2016, 03:06 PM   #13
NMWildcat's Avatar
I always wonder how some of the more weight conscious folks ever make it out of the driveway
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-29-2016, 03:22 PM   #14
mdstudey's Avatar
Originally Posted by mrpep View Post
The trailer weighs 4890 so add about 50 and were at about 5000 . Which equals at about 11500 with a full tank of gas.
Only 50 pounds of weight in the trailer? I don't know how many are in your family, but just clothes could easily add more than 50#. What about cooking utensils and food, toys, etc. Every time I get something for the trailer (or want to) I am reminded about weight and how little things can add up.
Chuck & Denise + Pata a.k.a the cg Gladys Karvitz
He is a Master Naturalist She is a quilter and RV Guru
2
008 Dodge Ram 2500 TX Edition2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights2018 The great adventure planned and will be rolling soon.
mdstudey is offline   Reply With Quote
Old 06-29-2016, 03:24 PM   #15
mrpep's Avatar
I weighed with everything in except for clothes so food utensils are on there and blankets and pillows and things etc
mrpep is offline   Reply With Quote
Old 06-29-2016, 03:37 PM   #16
JustB_Rad's Avatar
By making sure you have plenty of leeway to begin with
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 06-29-2016, 04:04 PM   #17
thebrakeman's Avatar
My TV a 2001 chevy express 1500 conversion van v8 5.7 L which weighs 5890 dry is rated for 11000 lbs gross combined weight and I am pulling a combined 11500 so am about 500 over and wonder just how bad this is ? The engine seems fine, the trans runs cool at 170 on the highway on a hot summer day. I get no swaying with the center-line TS husky WDH. Does all f this mean I should be OK ? I plan to take it out on a 180 mile trip in 2 weeks and am a bit concerned since I only hauled this once for 60 miles each way and traveled a bit lighter than I will be this next trip, about 200 pounds lighter. Should I be ok ?
So, it sounds like you feel 500 lbs is not too much. Fine. Good luck to you. But if you are looking for somebody to justify your decision, at somepoint, a decision about how much is too much will need to be made. 600? 700? 1500? What do you think?
I'm an engineer. And I know that engineers already bake in safety factors. Sure, some will say these ratings are generated by marketing. Reality is that marketing tells the engineers the targets, and we have to ensure that the parts hold up to those targets, WITH SAFETY FACTORS.
At the end of the day, you have to decide where the limit is. My recommendation to you is to obey your owner's manual. Any other statement here is simply an opinion that can't be backed up with anything.
thebrakeman is offline   Reply With Quote
Old 06-29-2016, 04:07 PM   #18
Ps - I did not read any of the comments after the OP. So my statements have nothing to do with any other comments. I simply know how these threads usually go. But nobody should take my comments as being directed towards them. I didn't read any comments.
Old 06-29-2016, 04:15 PM   #19
bikendan's Avatar
I'm sure glad those that are fine exceeding weight specs, aren't airline pilots.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-29-2016, 04:22 PM   #20
northstar1960's Avatar
plus or minus a bit won't hurt in the short haul but may bite you later with trans repair or engine work . i do believe all tv's have a bit of built in safety .TT's no built in safety and max there can be to much . those that think your causing danger to others because your 500 or even 1000 over have nothing better to do with themselves but nitpick every OZ
northstar1960 is offline   Reply With Quote
weight
