Old 01-31-2009, 04:37 PM   #11
CLASS "A" Senior Member
cfsoistman's Avatar
Smile
Originally Posted by NWJeeper View Post
Awesome! I had installed air springs on our old motorhome just before we sold it and the difference was incredible. Going over a twisty mountain pass close to home was much nicer as they helped to control the swaying of the rig. When we ordered our new GT378 I looked into them but I could not find any. Due to cfsoistman's post I found them! Happy Happy Joy Joy, I'm going to order a set......
Thanks cfsoistman....
I'm glad it helped you out. I'd like to take credit for thinking of it but the credit goes to Gary Bunzer, THE RV DOCTOR, I spoke with him after a seminar at the 2007 Hershey RV Show and he highly recommended it to me.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-31-2009, 09:16 PM   #12
NWJeeper's Avatar
cfsoistman,
Does your set have one or two air springs per side. I went to Firestone's web site today and did a search for 2008 F53 Chassis. Because the 37' Georgetowns are built on the 22000-26000 GVWR chassis the kit that comes up for it has 2 springs per side in the rear. The kit for the smaller chassis is only one as it was with our older 31' Fleetwood. The kit is for up to 2009 model year which ours is considered but the chassis in all actuality is probably a 2008.
I can't find the kit online anywhere to get a price but I would have to assume over $400 due to the extra bags.
One plus I can see is that the air compressor that Firestone has for the bags is the same one used with the air horns I just installed so all I need is the switches and gauges to be able to fill them from my seat.
I can't wait to get a set on my rig, they make such a big difference.
Ed & Wendy
www.nwjeepn.com
Old 02-01-2009, 01:05 PM   #13
KyDan's Avatar
I also have the air lift airbags.
I occasionally haul a 450 LB motorcycle in the back.
I almost always haul firewood right on the tail end.
The air lifts allow me to level my truck when it's loaded
heavy. They also allow me to haul "stuff".
Example-- one time I went to our local land fill where they were selling
pick up truck loads of compost- mostly composted leaves and ground up
tree branches. They guy in front of me had a 1/2 ton truck and when they
dumped the load in his bed, I thought his back bumper would drag the ground!!
I had 90 psi in my air bags and my truck settled down to just level.
Drive home from there was no problem at all.
I can't really say they do much for the bouncy rocking horse feel you get
when towing..... it may be less noticable when we're hauling the motorcycle
but they don't help much when I'm just towing my light weight trailer.
With just the trailer I don't have much air in the air bags anyway.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-01-2009, 09:52 PM   #14
cfsoistman's Avatar
cfsoistman,
I bought mine at Trucksprings.com I purchased the #2170 kit for the rear and #2070 kit for the front. I checked for a 2009 chassis and they don't list the 2070 kit for that year chassis. I'm not sure what change was made on the chassis. Hopefully they have something in the works for the front end on the 2009. A 2008 chassis lists both kits on their website.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-02-2009, 03:56 PM   #15
NWJeeper's Avatar
O.K.
The 2070/2170 kits per Firestones web site is for the F53 chassis 16000-18000 GVWR. Our F53s are the newer chassis that is 24000-26000 (at leas mine is and I though the '07s were too) and they list the kit for the rear as a #2474 which due to the weight of our rigs has two airbags per side. The fronts are listed as a #2476
Neither one was listed 4 months ago when I first started looking (that I can remember) they only listed the ones you had which I knew weren't right due to the weight of the rig. I have searched for the 2474s online and can't find a price so I guess I will have to call a local tow shop and inquire for a price.
Thanks....
Ed & Wendy
www.nwjeepn.com
Old 02-02-2009, 09:29 PM   #16
cfsoistman's Avatar
O.K.
Thanks....
Here's the link to the air springs I purchased. It is rated for the F53 Chassis 1999-2008 at 15,000, 18,000, 20,500 and 22,500 GVWR.
http://www.truckspring.com/VSearchResults2.aspx?cID=741
They are the Ride Rite Air springs. Shop by Vehicle, MOTORHOME, FORD, F53, 2008 and the info is listed in the vehicle applications area.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-02-2009, 09:46 PM   #17
cfsoistman's Avatar
They are the Ride Rite Air springs. Shop by Vehicle, MOTORHOME, FORD, F53, 2008 and the info is listed in the veicle applications area.
Firestone Ride-Rite Kit - Front 2070 works with the following applications:
My chassis is rated at the 22,500 GVWR and 26,000 GCWR when towing.
Motorhome:
Make Model Start Year End Year Additional Info
Ford F-53 1990 1998 (15,000, 16,000, 17,000 GVWR)
Ford F-53 1999 2008 (15,000, 18,000, 20,500, 22,500 GVWR) Will not fit THOR models.
This info comes from Trucksprings.com. I see what you're talking about on the Ride-Rite.com site. I'm not sure when that changed but it matched the other information last April.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-09-2009, 11:16 PM   #18
jspeedbump's Avatar
I had air bags but switched to "superspring" brand helper springs. my air bags were only 3 years old but i always had a leak somewhere or another. The supersprings did a fantastic job while having my truck camper in the back but otherwise the ride is kind of harsh when the truck is empty. I got the 5k model of Supersprings. just my 2 cents. Good luck.
Retired U.S.C.G.
One loving wife, 3 fantastic children 2 Beagles
2008 Silverback 30LRL Fifth Wheel
18K Pull Rite Superglide with a Fifth Airborne King Pin
Tekonsha Prodigy brake controller
2006 GMC Sierra 4x4 ext. cab LBZ
BullyDog PMT, Silverline 5 in. cat back Stainless Steel exhaust
Supersprings 5K, Ranch Hand Front Bumper
SSBC Force 10 Tri-Power HD 3-piston aluminum calipers and high performance pads with EBC sport vented rotors front and rear
and a partridge in a pear tree
jspeedbump is offline   Reply With Quote
Old 07-22-2009, 03:43 PM   #19
Had airlifts on my last 2 TV's, onboard compressor and it was the berries. I havent installed them on my 1500HD yet, but it is going to get them. Even with the WD hitch, sway control etc, it is still sloppy, the new one still would benefit from the bags.
cfd37buckeye is offline   Reply With Quote
airbags
