Old 03-23-2016, 05:19 PM   #1
Is it necessary to unhitch?
I was wondering if you absolutely need to unhitch your TT at the campground for the night if you are leaving early the next morning? It would save a little time. I didn't know if it would put any unwanted strain on TV. I have the stabilizer jacks that would still keep it somewhat stable. Thanks.
myezlife is offline   Reply With Quote
Old 03-23-2016, 05:27 PM   #2
caper's Avatar
It is not necessary to unhitch for an over night stop. I would unplug the TT from the TV. You could also drop the front jack to take some weight off the TV.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-23-2016, 05:30 PM   #3
PSUFan1's Avatar
X2 make sure the trailer is level front to back to keep the fridge running.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (20), Alyssa (15), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 03-23-2016, 05:40 PM   #4
Kilday4's Avatar
I agree ^^^^^^. I always put down the front jack to level and take some weight off the TV. Also put the stabilizer jacks down too.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
Old 03-23-2016, 05:49 PM   #5
^^^ x3
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 03-23-2016, 05:49 PM   #6
Ford Idaho's Avatar
As long as it is more or less level I leave it hooked.
Run the rear jacks down and push the slides out boom done dinner on the grill.
Old 03-23-2016, 05:51 PM   #7
I see you have a Surveyor TT,you did not list which model# but No need to unhook and if you need to deploy slides for Use you should use your Stab jacks and run your Tongue jack down to support also! Youroo!!
Old 03-24-2016, 12:14 PM   #8
X2 or X3. Don't need to unhitch for overnigh, but do unplug from your truck so as not to drain the battery.
2014 Coachmen Brookstone 325RL
2015 Chev Silverado 2500 Diesel.
ottawapaul is offline   Reply With Quote
Old 03-24-2016, 12:52 PM   #9
I agree with all of the above but would add what might be obvious: especially in short campsites, be sure your rig isn't sticking out into the roadway.
DrLewie is offline   Reply With Quote
Old 03-24-2016, 12:54 PM   #10
RollingDownTheHighway's Avatar
I left my TT connected to my truck for an entire weekend. We knew we weren't going anywhere, so no real need to disconnect it. I made sure the TT was leveled front to back and side to side, unplugged the power from the TV, lowered the front jack and, just relaxed all weekend.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 03-24-2016, 01:05 PM   #11
dieselguy's Avatar
For those of you have the "Level Up" hydraulic levelers on your rig ... do not push the auto level button while still hooked to the truck. Depend on attitude of entire hookup ... it could attempt to lift the rear of your truck off the ground.
dieselguy is offline   Reply With Quote
Old 03-24-2016, 01:14 PM   #12
Witch Doctor's Avatar
No that is really a no, no if it is hyd. system being the front has to dip down and come back up on auto, Electric system I don't know. You can always put it in manual mode and control each leg. Or if it is set up like my Hyd. I can drop down the front legs to stabilize the front, which by-passes the system, and then use my electric stab jack in the back. Hope that helps you....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-24-2016, 01:15 PM   #13
Boots49's Avatar
Send a message via Skype™ to Boots49
When we stop at a truck stop for the night, we park in the back, drop the legs to take sone of the weight off the truck. Then we open the slides, if there is room, put out our cones. wake up in the morning go inside & have my stake & eggs, ready to hit the road.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 03-24-2016, 01:20 PM   #14
Gold Miner At Heart
Papa-t's Avatar
X4
Papa-t is offline   Reply With Quote
Old 03-24-2016, 01:22 PM   #15
Boots I need to travel with you, Steak and eggs what a MAN... last time I was with Youroo he tried to give me yogurt.....YOUR THE MAN..
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-24-2016, 01:45 PM   #16
Boots49's Avatar
gljurczyk, always happy to have a wing man. Now that Sue & I are retired, we plan to be on the road more, hopefully I can drag her away from our new 1st grandson.
Al & Susanne
Aka: Puss 'n Boots
Old 03-24-2016, 01:54 PM   #17
Ford Idaho's Avatar
I guess it was not bacon flavored!
A violation not doubt.
Old 03-24-2016, 01:58 PM   #18
dieselguy's Avatar
gljurczyk ... I guess I didn't say it right. It figured it obvious you would need to manually put the front legs down as that is the process with "level up". I just wanted to warn others not to hit the auto level button after you took a bit of weight off your truck if they wanted to have all 6 legs on the ground. Do it all manually.
Old 03-24-2016, 02:42 PM   #19
What about the sway bars on an Equal-i-zer hitch? Can you leave them on overight or is it better to take them off?
2018 Grand Design Imagine 2600RB
2019 Chevy Silverado 2500HD 4x4 LT Crew Cab, Vortec 6L V8, 4.10 Rear Axle
Equal-i-zer 1,200/12,000# Hitch
Mark Ulmer is offline   Reply With Quote
Old 03-24-2016, 03:58 PM   #20
I leave my bars connected but use the tongue jack to take a little weight off and perhaps level the TT a bit.
Lee and Anne
hitch
