Old 01-25-2019, 12:17 AM   #1
Is it OK....
Is it OK to tow my trailer around town without hooking up the WDH spring arms? I need to take it a couple of miles to get new tires.
2013 Rockwood Mini Lite 2502S
DMS1 is offline   Reply With Quote
Old 01-25-2019, 01:04 AM   #2
It's probably not advised but you haven't given us enough info. What are you pulling? How much does it weigh? What are you pulling with? What are its towing specs? How fast will you be going?
Skip12 is offline   Reply With Quote
Old 01-25-2019, 02:23 AM   #3
Fishtexx's Avatar
How hard is it for you to fully hook up? Takes me less than 3-4 minutes. I never pull mine unless fully hooked up. I like optimum control of my trailer at all times, most other drivers have no consideration for the extra length/weight we are pulling.
Terry and Laurie
2017 Flagstaff 27RLWS
2020 F-350 7.3 Godzilla 10 speed 4X4 CCLB
Fishtexx is offline   Reply With Quote
Old 01-25-2019, 04:29 AM   #4
If your not going above 30 mph and on city streets it should be fine. But if you have to go on a highway or over 30. Then yes take the time and hook it up proper.
dodgemark is offline   Reply With Quote
Old 01-25-2019, 05:10 AM   #5
If the combination is stable and TW reasonable then yes you can. I consider my combo very stable so I tow mine 10 miles on the highway from storage to home and back at 60 mph without any problems. To be honest it tows better without any WD at all.
Dustyhd is offline   Reply With Quote
Old 01-25-2019, 05:47 AM   #6
BigH's Avatar
The answer is found in the manual for your tow vehicle.
24 Ram 3500 CC/SRW/LB/50 gal tank/CTD
2024 XLR 31A LE
BigH is offline   Reply With Quote
Old 01-25-2019, 11:48 AM   #7
I have a F150 and the trailer weighs 4000 lbs with a tonge weight of 400 lbs. The manual for the truck says I neeed a WDH for tounge weight over 500 lbs.
I think I will be fine, I am going to test it around the block. I am just going 4 miles to the tire place, top speed 35 mph.
Old 01-25-2019, 11:58 AM   #8
SailorSam20500's Avatar
Originally Posted by DMS1 View Post
II think I will be fine, I am going to test it around the block.
A better check - do a quick measure of your truck before hooking up. Measure from the top of the front wheel well opening to the ground. Then hook up. If the measurement doesn't increase by much, say under 1.5 inches you will probably be fine.
Big issue is unloading weight from the front wheels. No weight on the wheels, no steering.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 01-25-2019, 12:07 PM   #9
dcheatwood's Avatar
You'll probably be ok with that setup but it will handle different. Rear sag, bumps, etc.
2018 Forester 3011 DS
Old 01-25-2019, 12:08 PM   #10
Broken Toe
Cowracer's Avatar
I would not tow without the bars at any speed faster than I would be willing to hit a tree at.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 01-25-2019, 12:18 PM   #11
Oaklevel's Avatar
That short of distance in town should be fine. No need to over think things.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 01-25-2019, 12:47 PM   #12
Cabinfever97's Avatar
I towed my work trailer, averaged 4K with at least 500LBS of tongue weight, with a 1/2 ton chevy short bed for 6 years. Never a problem with no WD. I think you are more than fine. Just remember it will feel different without the bars.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
2005 Jayco Bantam Flier
Hensley Hitch
Cabinfever97 is offline   Reply With Quote
Old 01-25-2019, 01:16 PM   #13
Dave Lyon's Avatar
Based on your set-up, you're absolutely fine without hooking up your WDH bars for a few miles around town.
My trailer is about 2 miles form my home and I never use the WDH bars when shuttling it to and from storage.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 01-25-2019, 01:17 PM   #14
Towed mine to the dealer without it. 10 miles, city streets only.
TheWolfPaq82 is offline   Reply With Quote
Old 01-25-2019, 03:11 PM   #15
bikendan's Avatar
I'm guessing that you are using fictional brochure "dry" weights.
Those numbers are based on a stripped-down version of the trailer, not a real trailer.
Old 01-25-2019, 03:39 PM   #16
Location: Southern IL - across Mississippi from St. Louis
My tt is stored indoors about a mile and a half from my home. When I need to do any work on it, or we are planning on a camping trip the following week, I bring it home. I don't go over 50-55 mph. I've never had an issue...
Just Mike is offline   Reply With Quote
