Old 04-19-2011, 12:24 PM   #1
Is it ok to tow short trip with full fresh water tank?
We are doing a short weekender at nearby campground (26 miles). Instead of dealing with the pump station there would it be ok to bring water from home in my freshwater tank? I'm fine with tow capacity, and under gross weight on the trailer. Just didn't know if ~300 lbs of water would significantly change the ride on the one way up. Used to do it on the popup but that was a smaller freshwater tank... Thanks for any help.
brianb is offline   Reply With Quote
Old 04-19-2011, 12:39 PM   #2
Wanna Be Camper
SaskCampers's Avatar
Should be no issue. We have gone a few hundred miles or more with a full fresh water tank when going dry camping. Just makes sure your WD hitch is setup to compensate for the increased tongue weight.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-19-2011, 12:43 PM   #3
KyDan's Avatar
My trailer tows better with water in the fresh tank
due to more tongue weight.
You don't say what kind of trailer you have or
where your fresh tank is located.
If it's in the rear you probably don't want to go
far or fast with water in it but if your tank is in the
front you should be ok.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-19-2011, 01:00 PM   #4
The fresh water tank is located, I guess, in the center? It's over the wheels on the Salem 26TBUD. Well I guess I can try it, and if it's towing funny it's just a matter of turning a valve. Thanks!
Old 04-19-2011, 01:03 PM   #5
camping
tentcamper1's Avatar
we always travel with a full tank.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 04-19-2011, 02:01 PM   #6
bsmall's Avatar
I dont travel any great distance with mine full (56gallon) only because I have heard of some very flimsy mounting brackets. With mine, 56 gallon is a lot of weight bouncing down the road... On my trailer my underneath is covered/sealed so I can't see how the tank is mounted...
I ususally only put about 10 gallons in it just in case we use the bathroom or need the sink for what ever reason...
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 04-19-2011, 02:16 PM   #7
X2
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 04-19-2011, 03:20 PM   #8
Don't worry, they are designed for this purpose. I do it all the time. Randy
Old 04-19-2011, 06:26 PM   #9
Herk7769's Avatar
Might even make the ride better. Lower CG and higher inertia might make the normal bounce less apparent.
HAM CALLSIGN - KC3FFW
Old 04-19-2011, 11:04 PM   #10
Glenn5995's Avatar
We travel with a full fresh water tank about half of the time (on the way to camping) and with full holding tanks the other half of the time (on the way home).
Never had a problem.
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
