Old 03-25-2011, 08:21 PM   #1
Is my F250 big enough to handle a Puma 26-FBSS
Hi,
All I posted a week ago about getting a Puma 30-KFB. We didn't get the TT after reading the replies I got about weigth, lenght and WB. I didn't feel comfortable about getting a 34' camper for my first TT.
So now we are looking at a Puma 26-FBSS the specs are:
Hitch dry weight - 705 lbs
Dry Axle weight - 5460
Total dry - 6165
Carrying cap - 4662
GVWR - 10,865
Lenght 29'9"
Height 11'1"
The salesman was no help to me as he told me I could pull anything on his lot with my F250 which I felt was a ploy to sell me the 34' TT.
My TV is a 2005 F250 Lariat Super Duty Diesel with 35,000 miles:
Trailer Hitch Receiver 12.5K
3.73 ratio Limited slip
142" WB
Trailer towing package -
Suspension with Stablizer bar
Mono Beam Coil Spring
9800 GVWR#
Based on all the experience here what do you think? I plan on buying Airbags and a Equalizer hitch system.
Thanks for you help.
ALMcKinney is offline   Reply With Quote
Old 03-25-2011, 08:39 PM   #2
Send a message via Skype™ to scubieman
He is probably close to say you can pull about everything in the lot.
Your truck, that camper. Your truck wont even work up a sweat.
airbags not needed, unless you want it.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 03-25-2011, 08:41 PM   #3
For once, the dealer was almost right. Usually it is the opposite and they try to put the 34' trailers on a half ton truck and say it will be fine. Your truck will handle most any trailer you can find, except for a 5th wheel with a heavy pin weight.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
Old 03-26-2011, 03:27 PM   #4
Thanks,
We pick up the new camper at the end of April as we ordered it with some extras i.e. matress upgrade, different color, better vent fans.
The dealer suggested that I consider a Blue Ox system as it will allow me to back up without having to disconnect the bars as I would with a equalizer hitch.
what is the prefered system here?
Thanks again I'm glad I found the forum,
Al
Old 03-26-2011, 06:37 PM   #5
Wanna Be Camper
SaskCampers's Avatar
We have a Blue Ox and it is great. Also a great company to deal with, see my posts on them. Another thing is there is no noise with it like some other brands and you can dial in the amount of sway control you need.
Old 03-26-2011, 06:42 PM   #6
You don't disconnect the bars with an equalizer hitch. Not sure where you got that info from.
Your truck will pull virtually any travel travel you choose without any problem.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-26-2011, 06:53 PM   #7
I use a equalizer (on an f250 by the way) and never unhook to back up, it is not necessary.
Old 03-26-2011, 07:18 PM   #8
Bayouownbeer's Avatar
I pull his with my F250 14K. Yeah Im over on pin weight but have no problems with sway or power use airbags for added pin weight
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 03-26-2011, 07:37 PM   #9
Let me put it into perspective. There a a lot of new half ton trucks rated to tow more than the older 3/4 tons like my 2000 f250. They have softer springs, weigh a couple thousand pounds less and do not have full float rear axles.
Which do you think will be happier towing a 10k+ trailer in hills?
Which do you think will actually last while doing such a job?
Old 03-26-2011, 09:45 PM   #10
Is the equlalizer a sway and weight distribution system?
Thanks,
Al
f250
