Old 01-22-2016, 07:25 AM   #11
TURBS's Avatar
Is my trailer too heavy for my truck??
Empty dry weight means nothing.
Average user added weight is 1000 lbs.
95% of the time you'll go over your pin weight on your truck long before you reach max tow.
Look at your cargo carrying capacity sticker on your truck door or door jamb.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-22-2016, 07:27 AM   #12
acadianbob's Avatar
Originally Posted by todtc318 View Post
Dry tongue weight is 663# 1.5 is 828.75#. Max payload is 1531#. Sound ok?
I wind up pulling about 600 pounds out of my payload before I even start on the trailer. 350 pounds me/wife/dogs, 150 bed rolltop, 100 pounds side bars. Then there is what goes in the bed: generator, grill, inflatable kayak, "stuff" for another 200 pounds. My payload that starts out at 1820 is now down to 1,000.
The trailer dry hitch weight never includes trailer options, battery, propane tanks, the effects of what you load in the trailer. I think you could add another 200 pounds to the dry hitch weight quite easily. Don't forget the weight of the weight distribution hitch.
My guess is that you will be over your payload capacity. But, you now have enough information to figure it out for yourself.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 01-22-2016, 07:31 AM   #13
663X1.5 = 994?
I don't know what 1.5 relates to?
If the 663 is even accurate.....633+ 2-30 pounders = 110 + battery @ 42 = 785. I'd guess another 200 at a minimum for anything in the trailer ahead of the axles less the offset of stuff behind the axles.
I would anticipate the hitch weight to come in around 1000lbs.
Mr Havercamp is offline   Reply With Quote
Old 01-22-2016, 07:34 AM   #14
TURBS's Avatar
Originally Posted by Mr Havercamp View Post
663X1.5 = 994?
I would agree, if not more.
Let's not forget weight distribution hitch and sway control.
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-22-2016, 08:36 AM   #15
jlgail4309's Avatar
http://www.ford.com/resources/ford/g...0_r1_Jan12.pdf
Seems to me your loaded for sure. Pack smart and drive slow and learn your rig. Buy a good sway hitch and enjoy your camping !!
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 01-22-2016, 09:59 AM   #16
Don't forget the frontal area of your trailer can not exceed 60 sq. ft. are less for F150. It should be in your owners manual for that truck the correct numbers. Example 7.5x8 equals 60 sq. ft..
drc343 is offline   Reply With Quote
Old 01-22-2016, 11:14 AM   #17
Figure a loaded weight of 7400. Leaves 600 pounds for passengers, gear in the truck and hitch. You will be towing at the max rating but sounds doable.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 01-22-2016, 11:25 AM   #18
Should had gone with the ford with the 3.5 turbocharged it can tow 11000 lbs
Rkluge777 is offline   Reply With Quote
Old 01-22-2016, 12:12 PM   #19
Every TT needs a 450 Dulley to make everyone feel safe to be on the highway with you. You should be OK, just drive with extra caution and stopping distance. I can tow a hell of a lot faster than I can stop. Just don't.
pdqparalegal1 is offline   Reply With Quote
Old 01-22-2016, 12:14 PM   #20
Originally Posted by f5moab View Post
As Hondaman stated, don't forget the family, clothes, supplies, animals (if any), and any other cargo. And also don't forget to figure in any type of tonneau cover or tools that might also be added.
And also include the weight of your fuel as part of your payload.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
trailer, truck
