Old 01-26-2016, 11:38 PM   #31
CWSWine's Avatar
Originally Posted by bikendan View Post
you're passing incorrect info. air bags do NOT increase payload capacity or towing capacity.
not sure who told you that but they were WRONG.
Plus with a 10,600 pounds is dry weight for that 5er and an most likely put him over his GVWR and probably way over his max Max Axle Rating and tow rating also.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 01-27-2016, 06:50 AM   #32
Could be close to Jeff's Wildwood Heritage Glen?
368RLBHK
Specifications
Length: 42 ft
Ext Width: 8 ft
Ext Height: 13 ft 2 in
Hitch Weight: 2080 lbs
Dry Weight: 10924 lbs
Cargo Weight: 3156 lbs
Fresh Water Capacity: 54 gals
Grey Water Capacity: 60 gals
Black Water Capacity: 30 gals
Tire Size: 15"
2011 Ford F150 EcoBoost Specs
GVWR (lbs.): 7,100
GCWR (lbs.): 16,700 (with 3.73 axle)
Payload, mfr. max claim (lbs.): 1,760 (up to 3,060 with regular cab short bed with HD payload package)
Tow capacity, mfr. claim (lbs.): 11,300 (with 3.73 axle ratio)
Maverick50 is offline   Reply With Quote
Old 01-27-2016, 09:32 AM   #33
CWSWine's Avatar
With a 2500 Payload and 300 lbs of passengers and 50 lbs of other stuff in the truck plus hitch this is what you get:
You're adding approximately 650 lbs. to the truck. You have 1,850 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 7,400 - 9,250 lbs.
Here is the link to the numbers.
http://www.towingplanner.com/Calcula...50&tc=50&ct=FW
Old 01-27-2016, 06:10 PM   #34
You know if pulling a camper was up to the weight police on sites like this most campers would never get out of there driveway. DOT could care less, drive what you can afford and have fun. The only scales my truck and camper will see is passing DOT scales on the highway. Camp and have fun
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 01-27-2016, 06:21 PM   #35
CWSWine's Avatar
Or you could be in the camp of putting bags on the truck and if you can get some where close to level and it moves when you stomp on the gas it's safe to put you family and love ones in it and drive across the country.
Old 01-27-2016, 06:26 PM   #36
jlgail4309's Avatar
42 foot with a 1/2 ton !! WoW that's a lot of trailer !! Is that 3/4 to 1 ton load range ? I wonder if it will hold the road with a good side wind ?
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 01-27-2016, 07:19 PM   #37
Probably still safer than the twenty something in the suburban texting next to you . . .
Sent from my XT1254 using Tapatalk
madmaxmutt is offline   Reply With Quote
Old 03-10-2016, 02:55 PM   #38
jgump's Avatar
Wonder how I'd rate? :-). 33' wildwood 6355 dry, probably 7000-7100 loaded. My TV is a Jeep Grand Cherokee Hemi with quadra-lift air suspension. Max tow weight of 7400. Blue Ox WDH. Tows great. But I'm at or maybe a little above tongue weight and near or slightly over ccc. I drive 55-60 and its level, smooth, no crazy sway even with semis passing. Don't plan on driving to Calif (live in Ohio) Most trips will be within an hour or so and occasional 5-6 hour jaunts to the smokies. Would love a big truck but not happening anytime soon. Slow and steady and I'll be just fine as Spock says.
John
2016 Wildwood 27RKSS
2012 Grand Cherokee Overland (Hemi)
jgump is offline   Reply With Quote
Old 03-10-2016, 03:31 PM   #39
CWSWine's Avatar
John
Before I would put my love ones in vehicle that I knew was over weight I would at least put on the scales and see if I was under my axle max loading and even more important if I was under my tire max loading. But that's me - to each their own!!! Some people just don't seem to care or don't want to know.
Old 03-12-2016, 05:23 AM   #40
deebarjay's Avatar
http://www.ford.com/resources/ford/g...0_r1_Jan12.pdf
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
trailer, truck
