Old 05-21-2014, 10:38 PM   #11
thestrangebrew's Avatar
Ok. I guess I'll order 1k bars to be safe!
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 05-22-2014, 07:52 AM   #12
Brother Les's Avatar
I spoke to several RV shops about hitches and lift bars and they all said that what is labeled is 'light', all are beefed up. You can use the 800 pound and it will be fine and you can sleep good at night. This is for 'tongue' weight for the lift bars. The hitch head says 1,400 pounds. You will not enough come close to that hitch head weight and that is the carrying portion. Will you break or bent the lift bars? Not very likely with your unit at all. But then again, it is your unit and you are the one living with it and if 1,000 pound bars on your unit will take one more thing off your mind while you are driving, all the better, spend the money and get beefier bars. imo, they are not needed.
Brother Les
Old 05-22-2014, 08:13 AM   #13
Road-King's Avatar
I agree with Les, I would at least try those bars out before I spent the money on two new bars. My last TT i pulled with too light weight bars for the first year and I had too much rear end bounce. But I never felt like it was going to break or was unsafe. The next year I changed out the whole hitch system and I did get a better ride.
But you will always get different opinions on everything, do what ever fits within your comfort zone.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 05-22-2014, 10:27 AM   #14
Yea I was thinking about it and my tongue weight would only be about 50lbs over, *IF* my trailer was maxed. Otherwise, it'll be right at or lower than the 800lbs rating. Obviously a trip to the scales would be the best way to determine the loads, but I think I'll be alright for the most part.
Old 05-22-2014, 10:42 AM   #15
You will be fine with the lift bars that you have. My Brother-in-law has a 30 footer and he does not even use 'lift bars'. He does have a 'sway bar' on his, but has no need for a lift bar, his tow vehicle (F-250 Super Duty) laughs at his camper......
Brother Les
Old 05-22-2014, 02:32 PM   #16
Guest
I'm right at my spring bar capacity, rides just fine. Try before replacing.
John4th is offline   Reply With Quote
Old 05-22-2014, 02:34 PM   #17
Yea I'll give it a go before I buy anything. We're still working with the dealer at this point so I've got time. Hopefully by next week we'll have something.
Old 05-22-2014, 03:01 PM   #18
Ford Idaho's Avatar
I am with the try it first crowd, it just might save you a couple of bucks.
Old 05-27-2014, 11:52 AM   #19
thebrakeman's Avatar
So, is that a 1400 lbs head, with 800 lb bars? If so, and they actually work together, that's fine for any Roo hybrid. You'll want to get a separate friction sway controller ($50-$100).
thebrakeman is offline   Reply With Quote
Old 05-27-2014, 12:57 PM   #20
The 3rd pic is of the sway control. Should I have a pair (1 for each side)? Or is 1 enough. We've decided to go with the 233s and may be picking it up sometime this week.
