06-21-2018, 09:32 AM
Jacking up travel trailers
I'm taking my Hemisphere Lite down to the tire store to have new tires put
on.....Is there a correct way and/or a wrong way to jacking up a trailer?
I assume you place the jack somewhere on the frame? I have one of those
tire roll up one wheel things (it's a tandem axle) that I've used, but I'm sure
that they're going to want to jack it up and get both wheels off the ground.
Thanks!:
Salem Lite Hemisphere 232IS
Ford F-250 Super Duty Lariat Crew Cab v-10
06-21-2018, 09:50 AM
Kasual Kamper
Just don't let them do it on the axles!
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
06-21-2018, 09:51 AM
Couple years ago I was at Les Schwab in Brookings getting a potential blowout replaced. In the parking lot was guy with a 5er getting 4 tires installed. They had 4 jacks under each axle spring at the U-bolt area. Jacking up by the frame takes a lot of blocking to get the jack up high enough to lift the tires off the ground especially on larger trailers.
Not sure how high or low yours is off the ground. That may determine how they go about it.
06-21-2018, 09:52 AM
Why?
06-21-2018, 10:01 AM
if you have spring axles it is OK to lift under the spring shackles. If you have torsion axles don't lift on the axle use the frame.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
06-21-2018, 10:15 AM
Exactly.
06-21-2018, 10:35 AM
Oh, and don't let them take a look and think "Hey, he's already got jacks (stabilizers) at the four corners of the trailer, lets just use these."
06-21-2018, 03:23 PM
X2! Both Lippert & Dexter tell you (WARN YOU). Do not jack on the axles! Jack on the frame. Additionally, springs and shackles are designed to "suspend" the weight, not lift it.
2016 Salem 27RKSS
06-21-2018, 06:08 PM
This is the way my friend’s tire store did it. I’m assuming they’re doing it right.
06-21-2018, 07:05 PM
You do know that when the tire hits a drive entrance like a gas station or even a bump in the road that the tire is making the axle push up on the leaf springs?
Show me how it's different when using a jack under the U-bolts or the above simulation.
You're actually putting less upward pressure on the axle when lifting under the U-bolts as opposed to when the tire pushes up because the tire is further away from the U-bolts.
Lippert and Dexter say that as a CYA so some guy doesn't stick a jack 2' under the trailer and bend the axle. Kinda like don't drink hot coffee.
06-21-2018, 07:37 PM
Yes, I'm thinking that placing a jack on the frame has to be the safest bet....the tandem
axles are sprung with leaf springs I believe. It isn't a real tall trailer and they should only have to get it off the ground a couple of inches or so.
06-21-2018, 10:27 PM
Ideally, two jacks...probably hydraulic bottle jacks on blocking...one forward of the axles and one to the rear of the axles. This avoids putting abnormally high pressure on the tongue jack or landing jacks on a Fiver. One side at a time is more than enough for tire replacement work, but if the shop feels compelled to lift the entire rig, then 4 jacks and jack stands.
Yes, the suspension is designed to hold the weight of the entire trailer, but manufacturers don't warn against jacking on the axles for no good reason. If nothing, do it right for peace of mind.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
06-22-2018, 12:38 AM
If you read all the fine print in the frame and axle documents it's probably gonna say do not lift at the frame and do not lift at the axle. Everybody doing CYA...
For a dual axle trailer one axle could go up on a ramp unloading the other axle enough to take off the wheels. But as described above most tire shops use 4 jacks, one under each spring mount.
Basically you want the jack as close to the wheel as possible. Personally I've used a jack under the leaf spring mounts as well as on the wheel end of the swing arm (NOT the axle tube) of a torsion axle.
06-22-2018, 04:28 AM
The older, spring axles did not have a warning not to jack on them. Common sense says to jack under the shackles/U Bolts.............but no warning
The torsion axles have a warning.............from the same axle manufactures.
I think it is more than lawyers causing the warning, I think the manufactures know their product.
That is good enough for me.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
