Old 04-12-2016, 06:23 PM   #1
Jeep Grand Cherokee Limited
The 2016 Jeep Grand Cherokee Limited boasts a towing capacity of 7200#. The payload is 1610#.
In you opinion, what length TT and dry weight do you think it could safely tow?
THANKS!
kscamping is offline   Reply With Quote
Old 04-12-2016, 06:30 PM   #2
RKNOLA's Avatar
the only problem is there is a posted "dry weight" and then there is the weight after it is loaded with the many pounds of "camping stuff" that most of us tote around!
Weighing it after it is loaded at a truck stop might be a good idea.
Good Luck.
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 04-12-2016, 06:43 PM   #3
Good Luck.
Ok, I'll revise then...what is the max weight you would tow with the TV and max length of TT?
Thanks!
Old 04-14-2016, 07:47 AM   #4
jgump's Avatar
THANKS!
Kscamping - I have a 2012 GC Overland with Hemi. My payload sticker only says 1050lbs so not sure why the diff. I tow a 33' TT (Wildwood 27rkss), dry weight is 6355 but tow weight is about 6800 with our stuff in it and the battery, with a blue Ox sway pro WDH. Sits perfectly level. I do have the quadra lift air suspension which is awesome. Tows fine. I'm close on payload limits for sure and the wheel base isn't optimal but 55-60 mph on the highway is no prob. I can definitely feel it back there but nothing scary.
John
2016 Wildwood 27RKSS
2012 Grand Cherokee Overland (Hemi)
jgump is offline   Reply With Quote
Old 04-14-2016, 08:24 AM   #5
MtnGuy's Avatar
Length: A good rule of thumb is to divide the tow vehicle wheelbase by 5, and that would be the maximum total length in feet for a conventional upright travel trailer. With a wheelbase of 115", you might want to consider a trailer 23' or under.
Weight: Load up the family and expected camping gear, and head to some truck scales. Subtract that weight from the GVWR listed on the drivers side door pillar, and that would be maximum tongue weight the Jeep can handle. Keep in mind, the actual tongue weight is going to probably be 150-200 lbs. over the listed dry tongue weight.
With those 2 things in mind, I don't think you will be anywhere near your 7200 lb. maximum tow vehicle weight rating.
Old 04-14-2016, 09:45 AM   #6
We towed a 27' Trail Cruiser camper with our 2007 Grand Cherokee diesel for 3 years before we were able to purchase our first truck.
Our camper was very light, 4200 lbs dry and tongue weight was about 650 lbs loaded. We were told by many that it wouldn't work and it would be dangerous. Using an equalizer hitch, it towed just fine in all conditions. I first tested it on an early Sunday morning on the interstate and took it up to 85 mph to see how it did. Knowing that it was good at that speed made me feel more comfortable knowing I would only be going at 60 to 65mph most of the time.
We used and equalizer hitch and sing its praises to anyone who will listen. We always seemed to be caught in a rain storm whenever we left to camp and one was very windy with 45mph cross winds. We ended up slowing down to 40 mph due to visibility and the trailer handled the cross winds very well. We did notice that radial trailer tires seemed to be a little more squirrely and we switched to bias ply trailer tires which made things ride more stable. I suspect short wheel base and radial tires (at the time) didn't do as well together as I hoped they would.
We do not have children and carried all of our cargo in the camper. Our Grand Cherokee's suspension was a little soft and could have benefited with airbags.
I would not tow a camper that long with a G. Cherokee unless it was very light like ours.
When people talk about wheel bases, I point them to semi's and ask the to compare a semi's wheelbase to the length of the trailer.
If you have the $$$ and inclination, consider a Hensley hitch and airbags and you should be ok as long as you don't exceed axle and cargo carrying capacities. Good tires on tow vehicle are a must. Soft P rated tires are a no go unless all you are towing is a popup.
Skyliner is offline   Reply With Quote
Old 04-14-2016, 10:24 AM   #7
MtnGuy's Avatar
A semi setup puts the pin weight over heavy duty axles, not sticking out behind the bumper of a vehicle with a soft set of SUV springs. Apples and oranges.
But, just in case that doesn't justify the difference, consider this: Many of the newer conventional road tractors with sleepers have wheelbases in the 285" range. Using the formula that I posted above, they could pull up to a 57' trailer, where 53' is now the legal limit.
Old 04-14-2016, 10:42 AM   #8
CWSWine's Avatar
So 1 ton long bed DRW has a 173.4 wheelbase so divide that by 5 and you get 34.48 feet max length. My 1 ton with 143.5 max length would be 28.7 feet. That just doesn't sound right.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-14-2016, 11:32 AM   #9
I tow a 6700 pound, 30 foot, TT with a Dodge Durango. Basically the same as the Grand Cherokee. I use the Blue Ox WDH and and do not have problems between 60 and 65 mph. I have upgraded tires on the Dodge to an extra load tire which gives me stiffer side walls and that improved the ride while towing, less side to side movement when trucks pass.
frisbyh is offline   Reply With Quote
Old 04-14-2016, 12:48 PM   #10
jgump's Avatar
Good to hear frisbyh! I haven't done the tire change but I do pump them up to near max psi. Definitely helps a lot. I figure I'm at or probably over max tongue weight but with the blue Ox I think it's doing a good job distributing the weight. I wouldn't go to California (I'm in Ohio ) but within a couple hours radius I'm not concerned.
John
cherokee
