Old 06-22-2016, 12:39 PM   #11
bikendan's Avatar
Originally Posted by Hobbitzis View Post
Ok so you are missing the question here. I no longer have the Cherokee and the owners manual for that particular car did say to tow in 1.
well, i've never heard of any vehicle with the D, 2, 1 selection, that had 1 for towing.
unless it was for a short pull, on a steep grade.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-22-2016, 12:46 PM   #12
Since you have a fairly light trailer, just put in D and go.
If you find the transmission downshifting a lot (dropping a gear, then going back up a gear, then dropping a gear again... and continuing this process), use the "-" to downshift and hold it in that gear. If the transmission still hunts for a gear, use the "-" to drop another gear.
Letting the engine run at a higher RPM, in a lower gear, is better for everything.
The "+" and "-" on your Jeep allows you to restrict the transmission to which speeds/gears it can use. You're setting the "ceiling". When utilized, the transmission will operate normally, except it won't go into a gear higher than you set with the "+" and/or "-". Try it out anytime, towing or not. You'll figure out what it is doing pretty quick.
325BH is offline   Reply With Quote
Old 06-22-2016, 12:47 PM   #13
Kenny kustom's Avatar
Here's a direct fit trans cooler for your jeep.
https://www.amazon.com/Derale-20561-.../dp/B004XOO6C2
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-22-2016, 02:56 PM   #14
Jmsx2's Avatar
I have a 2014 Jeep Wrangler 4 door unlimited and am towing a 1600 lb pop up camper. The dealership says I don't need a transmission cooler as I am towing all flat land. My question is I only have drive and a plus and minus sign that I have no idea what that is for. I used to tow in 1 on my Cherokee but the wrangler does not have that so do I just tow in drive? Any help would be appreciated.
I'm a big Jeep guy. My wife had a 2012 Unlimited & I have a 2013 Rubicon.
If your Jeep has a factory tow package it already has a cooler. It's also rated to tow 3500 with the 3:73 diff.
Jmsx2 is offline   Reply With Quote
Old 06-22-2016, 03:03 PM   #15
Jmsx2's Avatar
Name:	ImageUploadedByForest River Forums1466625689.049646.jpg
Keep it in D too. Our Hybrid came in at 3200# and we had no issues towing it.
John & Janine
Pazzo the Maltese
2014 Georgetown 328 TSF
2013 Jeep Wrangler Rubicon (Toad)
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Old 06-22-2016, 03:06 PM   #16
Jmsx2 in post #6 OP states he does not have a factory tow package. Therefore he should add one to help cool the trans.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-22-2016, 03:18 PM   #17
Jmsx2's Avatar
Yep. Then he'll need a cooler.
John & Janine
Pazzo the Maltese
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 06-22-2016, 10:40 PM   #18
7 Year Class A RV'er
You do know you can monitor your transmission temp in the smart center on the dash, right? Also, the owner's manual tells you in detail how to use the manual shift mode on the transmission. Comes in handy when off-road.
2015 Legacy SR340 360RB
