Old 06-22-2016, 08:14 AM   #1
Jeep Wrangler unlimited tow gear?
I have a 2014 Jeep Wrangler 4 door unlimited and am towing a 1600 lb pop up camper. The dealership says I don't need a transmission cooler as I am towing all flat land. My question is I only have drive and a plus and minus sign that I have no idea what that is for. I used to tow in 1 on my Cherokee but the wrangler does not have that so do I just tow in drive? Any help would be appreciated.
Hobbitzis is offline   Reply With Quote
Old 06-22-2016, 08:36 AM   #2
fx2
The +\- should be a gear selector
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
Old 06-22-2016, 08:52 AM   #3
Bowmanville SVT255S's Avatar
gear selector
Not sure what you mean by towing in 1? Did you tow the entire time in 1st gear
A lot of modern automatic trans. now have a sport modes allowing a person to sequentially shift their own gears no clutch required. Can be fun an useful to some but useless in the grand scheme of things.
You should be good in just D just be easy and consistent with the throttle to reduce shifts OR you could try the +/- thing. That may reduce you shifts but be mindful to shift down and up manually as needed
2015 Ram Crew Hemi
2005 Surveyor SVT 255RS
Bowmanville SVT255S is offline   Reply With Quote
Old 06-22-2016, 09:19 AM   #4
Towing in 1
Ok so the Cherokee had drive and then it had 1 and 2. I was told drive was overdrive and 1 and 2 were lower gears and to tow in 1. Keep in mind I am talking about an automatic. Well the wrangler does not have anything but drive and + and -. Whatever they are. So would I tow in drive.
Old 06-22-2016, 10:20 AM   #5
bikendan's Avatar
Whoever told you to tow in 1, is an idiot.
How about reading the Towing section of the Jeep's owners manual?
Equalizer WDH
Old 06-22-2016, 10:28 AM   #6
Towing in 1
Ok so you are missing the question here. I no longer have the Cherokee and the owners manual for that particular car did say to tow in 1. The wrangler I have now and am going to tow with does not say anything about towing except for weights in its manual. I called the dealership who said they thought you towed in drive and it should be alright without a transmission cooler but what does think and should really mean? They won't commit to an answer. So I figured I would ask other jeep owners what to do. I appreciate your help but the manual does not state much about towing. I do not have the factory tow package. Just had them add a brake controller and hitch to the jeep when I bought it.
Old 06-22-2016, 10:33 AM   #7
DaGrinch's Avatar
You can't go wrong with installing a transmission cooler - it'll help in the long run and fairly cheap to do, as well as being cheap insurance to hopefully keep from overheating the tranny - even in the flatlands.
Use "D" for your gear selection. You should have no problems.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-22-2016, 10:58 AM   #8
Drive in Drive
2015 Ram Crew Hemi
Old 06-22-2016, 11:30 AM   #9
Put it in drive "D" and let the automatic trans do its thing, also adding a tranny cooler will help trans live a long and healthy life.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-22-2016, 11:51 AM   #10
Kenny kustom's Avatar
When you push towards the -
You will see a number on the dash, behind the D.
That's manual shifting.
Since the jeep has no tow mode, if you find it downshifting a lot, push the shifter till you see 4.
That locks it in fourth.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
