Old 09-02-2011, 10:57 AM   #11
Brigitte
boubou's Avatar
Thanks Caper, I guess I'll have to give that a try. Are the bars the same length? different install again?
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 09-02-2011, 09:13 PM   #12
caper's Avatar
They are the same length. There should be little difference in the setup. Because the bars are heavier you might need less links. Other then that everything is the same. I had a white knuckle ride before changing the bars.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 09-02-2011, 09:15 PM   #13
caper's Avatar
The bar length is the same. The only difference is the weight of the bars. Because of the heavier bars you might use less links.
Terry and Janet
2007 Ford F150
Old 09-02-2011, 09:15 PM   #14
Brigitte
boubou's Avatar
I wouldn't call it a white knuckle ride but I didn't think it was quite normal.
I'll change them over.
Superglide 2700
Timbrens
Old 09-03-2011, 06:59 AM   #15
KyDan's Avatar
Sounds like Terry is on the right track.
You are near the top of your bar weight rating.
If I were you, I'd try the stiffer bars.
In my case I'm at about 450 on the tongue and don't think I want
bars rated higher than 800.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 09-06-2011, 08:55 PM   #16
Brigitte
boubou's Avatar
Less links? I' m on the very first one! Meaning the 800 lbs can barely attach it's so stiff. Arg confusing.
At the dealer site they say tongue weight 750 lbs. I did not weigh it but assume it's empty
Might not be able to attach 1200 lbs (reese goes from 800 to 1200).
Superglide 2700
Timbrens
Old 09-07-2011, 08:16 AM   #17
MtnGuy's Avatar
Originally Posted by boubou View Post
We got the Reese Dual Cam HP installed today (except for the sway control, part didn't come in yet)
had a hard time with install, the A frame on Shasta Revere is really wide and had to end up putting the chains on last link after changing the angle on the ball to give it more play.
The sway control will give us an extra link or two to play with when installed.
My problem is that when driving, it feels like the truck is jerking rhythmically. like tug of war. What causes this?
Huh ??? The 1st post indicates the last link, and the last post indicates the 1st link. I am confused.
There should be a minimum of 5 links of chain under tension between the spring bar or dual cam to the snap up bracket. More links are good, less is bad. How many lengths of chain do you have between these 2 points ??
If the listed dry weight of the tongue is 750 lbs., then the loaded tongue weight might be in the neighborhood of 900 lbs. 800 lb. bars will not handle that kinda weight.....1200 lb. bars may be needed. I travel with a 700 lb. tongue weight and 800 lb. spring bars, and feel that that is about the maximum those bars will manage.
How about a photo of your setup ??? A picture of the hitch including the reciever and trailer tongue, as well as a total shot of the TV and TT on fairly level ground would be great.
Old 09-07-2011, 08:47 AM   #18
Brigitte
boubou's Avatar
Sorry about the confusion, might have something to do with my own confusion lol
The bars are using all the links, as it is on the very first link so I guess that's good, lots of clearance. That will change once the Dual cam sway control gets installed (they weren't in yet and had to bring the trailer home).
I called Reese and they too agreed about getting the 1200 lbs bars so I will get them changed to those.
I'll take a picture when it's hooked up again.
Superglide 2700
Timbrens
Old 09-07-2011, 09:26 AM   #19
MtnGuy's Avatar
If you have all of the links under stress between snap up brackets and the spring bars, then you may be able to use 1 link less (under stress) and get better weight distributing for the time being before you get the 1200 lb spring bars. You may also be able to tilt the head assembly forward, and use even less links if ground clearance is a problem.
You will probably need to adjust everything, and do the fender measurements again once you get the 1200 lb. bars.
I got 800 lb. bars with my setup, and kept tilting the hear assembly back to get the proper weight distributing with my 700 lb. tongue weight. I bought 1200 lb. bars, but after a couple of trips I felt they were just too stiff. I also had a rub problem with the spring bars and the dual cam yoke, so per Reese, I went with a 1" raised ball. I was able to go back to the 800 lb. spring bars, with the head assembly tilted all of the way back, and now "just barely" get the lift that I need with 5 links of chain under stress. With your listed dry weight of 750 lbs. on the tongue, I can see where you can be having the problem. The 1200 lb. bars will probably be a much better fit.
Old 09-07-2011, 10:06 AM   #20
acadianbob's Avatar
A cushioned weight distribution insert might help your front and back motion issue.
Convert-A-Ball Cushioned Weight Distribution Shank for 2" Hitches - 10,000 lbs Convert-A-Ball Accessories and Parts AMAC1
I use this insert and it works well for me. Good luck!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
reese, shasta, shasta revere, towing
