Forest River Forums
Sunline User Photos
Old 11-02-2011, 04:38 PM   #1
rbarrieau's Avatar
? jump TT Battery ?
Problem is I left my TT at the camp site buried in snow with a dead battery and no power.
Question= Can I hook-up jumper cables to the TT battery to operate slide and power tongue lift without issues. The seven pin connection does not seem to offer much power to the TT with TV at idle .I want to get my unit home tomorrow , while the weather cooperates.
Please any imput would be appreciated.
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
rbarrieau is offline   Reply With Quote
Old 11-02-2011, 04:46 PM   #2
Moderator
acadianbob's Avatar
As long as your battery isn't frozen, I don't see why not . . .
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
Old 11-02-2011, 05:38 PM   #3
Boyd's Avatar
Red to Red and Black to Black
To be safe, disconnect the cables from your TT battery and clip direct to the cables running into your trailer. I really don't think you'll have problems either way, but be safe and connect to the powering battery last so you are well out of the way should a problem occure.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 11-02-2011, 05:47 PM   #4
flyrotor's Avatar
Originally Posted by Boyd View Post
To be safe, disconnect the cables from your TT battery and clip direct to the cables running into your trailer. .
WTH? never heard of that...
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
flyrotor is offline   Reply With Quote
Old 11-02-2011, 06:12 PM   #5
Boyd's Avatar
Be safe
Live and learn...IMHO lifting the cables from the dead battery would be eliminating the possibility of a frozen battery popping in your puss. And, if the TT dead battery is left connected, it'll be drawing down on the charging battery making for a more difficult slide retraction. It's best to disconnect the dead battery and use the good battery to pull in the slide, return home and give the dead TT battery a good charge. ~~ I think you could accomplish the task by leaving the dead battery connected but why take the chance of smoking the charging system of the charging battery and leaving you shivering in the cold wondering what to do next. Be safe.
Old 11-02-2011, 07:26 PM   #6
rbarrieau's Avatar
thank you for the imput .. I will give it a try tomorrow morning.. I'll let you know how it goes...
It has been a long week with the more than 750,000 homes without power in the state (CT) and many roads still impassable due to downed trees and power lines.
Old 11-02-2011, 07:27 PM   #7
sherdep's Avatar
just make sure to keep the jumper cables from touching each other while connected to your trailer especially if you are inside and no one is watching the battery cables.
Good Luck and make it back safe
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 11-02-2011, 07:38 PM   #8
frankm's Avatar
Worse case you should be able to crank it in manually, right?
Also, remember driving home without a working TT battery your TT brakes won't engage in the event of a disconnect from the TV.
Frank & Rita M
2008 Ford FX2 F-150 3.73 CC 139" WB w/EQ4 WDS
2011 Rockwood 2702SS
frankm is offline   Reply With Quote
Old 11-02-2011, 07:54 PM   #9
rbarrieau's Avatar
how long would it take for the TV to charge The battery enough for break away brake to work when driving .. I am only on the road for 30 miles ...
Old 11-03-2011, 06:28 PM   #10
rbarrieau's Avatar
jumping the TT battery with the TV worked out very well . Slide pulled in with no hesitation also used the power tongue jack when it was jumped..in a pinch I think I coulsd run my furnace.
Thanks for all your imput.
» Online Users: 616
111 members and 505 guests
1l243, 2Susan, Adony, alphadog99, alpinemike, Andy R, autorot8, Bandit114, Barney1, bclemens, bob34787, bobbygee, boubou, brandon0214, brookside, Browndog, cabane, camper1999, case1175, Chino63, chof16, CM BOXERS, comfun1, csichoice, dashonthedash, dasimser, Dave_at_FastwayTrailer, ddemme, dec1952, deerslayer, Dennis Carpenter, Deputyseven, DGrissom, dimurrrw, djorgensen3, dogwood36322, dretired, dummin4fun, dunnnc, electrician549, Flying dutchman, frfan, gjj, Happy Vibe, heytomgraywolf, HWII, Indy Steve, isz, itat, JamesR, jasni, jaxfl, jes520, JJones, jsutherl, jwuertz, J_KHawthorne, kegoneill, Kevin-and-Julie, kfroe, kjoh75, leanne, LFugate, lochsa, Mad4sax, MargeM, merlin66043, mesquiteguy, Mountainmanbob, Mr. Legato, mrmurph, mtnguy, pappcam, PrairieBoy, PUMA2011BUENA, punkaccountant, pwrplay, reyob, rjshiflet, rodcop9405, ronhanson, rotorhead1250, Rsgtivr6, rstewart06, Rugged Brown, RV Guy, SabreMarv, SabreSam, Sailfish Bret, sbond, scout800, ses, snowbrid, steeleshark2, Steve7575, texashatter, TheFlagGang5, Tincup13, tking1866, tmmar, toleworks, tomjsas, torben, Triguy, unhcharger25, viper48, wayne anthony, we2lovecamping, whj77372, Wichitalineman, woodchomper
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
