Old 04-29-2016, 06:34 PM   #1
Charles Firth's Avatar
Just an observation
I know there is a lot of discussion about weight distribution hitches and the balance needed for a safe tow. I live in Eastern Va and travel I 64 a lot. Just recently I have seen quite a few new rv's being delivered. Most by big rig diesels. I am assuming the RV's are being delivered to the dealers. I have yet to see them using a wd set up. They are just hooked to the ball hitch and the power cord for the lights and brakes. And they are usually hauling at a pretty good clip. They seem to tow alright and look to handle well. Are we over doing it ? I would not tow my Windjammer without a wd hitch. Maybe they just have more experience, I am sure they drop it at the dealer and head back o the factory to pick up another one . Any thoughts ??
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
Old 04-29-2016, 06:39 PM   #2
dcheatwood's Avatar
I, too, have seen that. Some reasons may be that the trucks are 1-ton , 6- tired trucks that can handle the load considering the trailers are empty, no propane, battery, water, etc. Another reason, I suspect the main reason, is that those guys are in a hurry as they are paid by the unit. Maybe some RV delivery folks here will comment with more detail.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 04-29-2016, 06:59 PM   #3
The manufaure doesn't install WD hitch from factory and a hauling company isn't going to take the time (or liability) to set one up to deliver to dealer, where it would have to be removed.
notaz3 is offline   Reply With Quote
Old 04-29-2016, 07:06 PM   #4
Oaklevel's Avatar
An F350 - 3500 duelly etc is a whole different animal than a 1/2 ton pickup. My duelly has a heavy 7 leaf spring pack and rated 4500 lb cargo cap. So tongue weight is not an issue. I have towed with a 1/2 ton for years but a duelly is solid towing and a 1/2 like your on skates trying not to fall over without a WDH
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 04-29-2016, 07:41 PM   #5
dcheatwood's Avatar
Yes. That's what I was getting at. The duelly platform prevents a lot of sway.
Old 04-29-2016, 09:00 PM   #6
Just an observation
I don't think the dually prevents sway, but it would not affect the truck as much giving the operator an easier time braking the trailer, instead of having to fight with the truck at the same time.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-03-2016, 01:48 PM   #7
thebrakeman's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Well, there's preventing sway, and then there's resisting sway.
The trailer doesn't know what type of truck it's being pulled with. But with 4 rear tires instead of 2, the dually has twice as much rubber resisting that side-to-side motion. And those tires are all HD truck tires, while a 1/2-ton is likely standard radials. And the HD suspension isn't going to lean like a half-ton.
All taken together, whatever forces the trailer is trying to exert, the truck has much better ability to resist.
thebrakeman is offline   Reply With Quote
Old 05-03-2016, 01:50 PM   #8
I'm never thought about it. Is this how every single trailer is delivered to trailers all over the country? I would think they might use the rail system.
Old 05-03-2016, 02:08 PM   #9
Who Dares, Wins
doc73's Avatar
Nope driven from point A to point B
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 05-03-2016, 02:12 PM   #10
Flybob's Avatar
I doubt that any are shipped by rail. This is one reason a trailer can leave the factory in good shape and have issues once it gets to the dealer. Not saying delivery drivers are at fault, just that the RV may have had many miles on it since it was built.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
