Old 04-22-2013, 07:16 PM   #11
caper's Avatar
I would replace the tire. The patch will be a weak spot on the tire and a higher risk of a blow out.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
caper is online now   Reply With Quote
Old 04-22-2013, 08:35 PM   #12
Fulltime family RVer
Other views of the tire/nail. It does seem pretty close to the edge.
QCC- that thread hits pretty close to home! I do carry my torque wrench and my sockets fit (I've ensured the tires were torqued to 100 psi at least- no clue if they're way higher; I've just been checking that my wrench clicks). I'd never thought of using the LynxLevelers to raise up the one tire so it hangs free. Sure woulda made finding the nail a lot easier if it was free spinning (I pulled the truck/camper forward, would run back and lay down and look and then go do it again). I'm going to have to try it.
I have no idea how the aluminum pretty wheels/hubs??? come off or go on or anything.
I guess my plan was always just to call GoodSam ERS (like I've used AAA a couple of times in the past- never for a tire, knock on wood!).
Barry - I was thinking the spare is the same tire as the rest and would be able to be the new driver's side rear tire. I didn't actually look and really don't know.
Guess I've got some learning to do... fortunately, the next trip isn't until mid-May.
And finally, I'm pretty mad at myself for not checking this before I left when I knew something was up. It was 98 miles to the campground and a good 85+ was highway. Fortunately, nothing bad happened.
ID:	28717   Click image for larger version
ependydad is online now   Reply With Quote
Old 04-22-2013, 08:52 PM   #13
On my RV the tire is the same, but the wheel is very different. I don't know about yours.
Old 04-22-2013, 08:55 PM   #14
QCCowboy's Avatar
I believe the wheels are white on the spare. Same size tire, just not the nice aluminum rims.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-22-2013, 09:03 PM   #15
Hmm. Sad news. I don't think I ever looked at the spare...
Ok- so there's more to this. I need to get the wheel off and take it to the tire shop. I'd have to think pretty long and hard if there's a tire shop that has a big enough parking lot for me to take the whole trailer there... Love the suburbs for all sorts of other reasons, just not its wide open spaces.
Old 04-22-2013, 09:07 PM   #16
QCCowboy's Avatar
I took the tire off, put the spare on (EDIT: I then took it off the leveling blocks and had both tires resting on the ground) and then took the tire with the problem to the tire shop. That way I didn't have the weight of one side of the camper sitting on one tire for too long. When I got the tire fixed, just did the same and swapped out tires. Good news, is with the spare on you can move it if you have to.
2014 Sabre 36QBOK
Old 04-22-2013, 09:10 PM   #17
Makes sense. Hopefully the Lynx blocks idea works with this EquaFlex suspension.
Guess I have a camper project this weekend...
Old 04-22-2013, 09:14 PM   #18
QCCowboy's Avatar
Had the same suspension on my last Sabre. Worked like a champ! Good luck...I'm sure it will be a piece of cake for you.
2014 Sabre 36QBOK
Old 04-22-2013, 09:15 PM   #19
Ha. Haha. HAHA. HAHAHAHAHAHAHAHAHAHA- you don't know me well enough yet, then. :-) I make easy mechanical things hard. But, if you need a computer system programmed or an online store, perhaps- that I can write from the ground up by hand.
Old 04-22-2013, 09:17 PM   #20
I guess let me ask a different question - am I ok to replace just this one tire? The tires are stamped June/2012 and have about 5,000-5,500 miles on them.
