Old 04-22-2013, 09:33 PM   #21
caper's Avatar
It will be OK if you replace with the same brand and style of tire.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-22-2013, 09:38 PM   #22
QCCowboy's Avatar
Ha. Haha. HAHA. HAHAHAHAHAHAHAHAHAHA- you don't know me well enough yet, then. :-) I make easy mechanical things hard. But, if you need a computer system programmed or an online store, perhaps- that I can write from the ground up by hand.
LOL....so maybe this will help. Try using agile methodologies and think of the need to change the tire as a theme, then break each step down into sprints. It will make each task seem less daunting and you will reduce your potential for defects
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-22-2013, 09:43 PM   #23
Fulltime family RVer
But don't these campers come with no name "Ed's" tires? Will a tire shop actually carry them?
Old 04-22-2013, 09:44 PM   #24
LOL! That's exactly how I built a pair of kayaks a few years ago.
Old 05-05-2013, 12:30 PM   #25
Guess it's to NAPA or Autozone for a heavy jack.
Old 05-05-2013, 12:37 PM   #26
Attachment 29659
Or get some wooden blocks to raise it another inch or two. Make sure you break the lug nuts loose before you get it off the ground.
Old 05-05-2013, 12:44 PM   #27
I have about 4 fingers of clearance before I bottom out the front tire - maybe 2-3". I should have room to go a little higher and I do have a few 2x10s.
Old 05-05-2013, 12:48 PM   #28
Shouldn't be a problem, the suspension is probably at it's limit or very close to it and you have plenty of clearance. AGAIN, break the lug nuts loose before you get it in the air.
Old 05-05-2013, 12:50 PM   #29
QCCowboy's Avatar
Back up or pull forward a little more and try to get the wheel that is on the ground as close to the blocks as possible. I am pretty impressed that you got it up on those blocks without a ramp. Or did you drive it forward and off the blocks?
2014 Sabre 36QBOK
Old 05-05-2013, 12:53 PM   #30
Understood about the lug nuts. I had that epiphany this morning laying in bed. I was thinking of making sure I can get it airborne and then lowering it back down to the ground before doing the lug nuts just to prove that I'll be able to get it there. Then getting it down, breaking the lug nuts loose and re-raising it. Extra work, for sure- just a bit chicken since I've never done anything like this before (literally never even changed a car tire). This may be a bad idea as the lynx levelers shot forward when I backed off of them last time.
Is it ok to pull forward/backup with the lug nuts broken loose? (Not driving it- just 6-8 feet in either direction.)
