Old 04-19-2016, 07:40 AM   #11
I have a 2013 primetime avenger 26bh. I put everything in front of camper, inside and in underneath front storage. Maybe that's why my tongue weight is at 20 %??? I packed all toward front because I thought only only preventing sway. I do have swaybar.
DebMar is offline   Reply With Quote
Old 04-19-2016, 08:04 AM   #12
MtnGuy's Avatar
Originally Posted by DebMar View Post
Yes, we left the wdh head on truck... Forgot to take it off when weighing only truck. And yes all passengers, fuel the same. Did all weights in same day.
IMHO, the WDH assembly (excluding spring bars) should be left on the truck during the solo weigh-in to give you a true tongue weight. The WDH shank and head assembly should not be figured as tongue weight, as it is part of the truck. You did good.
Old 04-19-2016, 08:18 AM   #13
I'm at 20% tongue.. So if I moved some of the stuff I packed in front of camper back, like closer to axle, will that help reduce the tongue weight?
Old 04-19-2016, 08:24 AM   #14
AquaMan's Avatar
Moving anything from the front towards the back will reduce tongue weight. How does your camper pull? If it does fine and you don't have issues, (other than high tongue weight) I'm not sure I would mess with it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-19-2016, 08:46 AM   #15
Head Rambler
I agree, don't worry about it if it's not causing you any problems.
Gotta go campin!
Old 04-19-2016, 09:28 AM   #16
Debmar, having read all of your posts on this issue I think you are good to go as is. You are now at the point where you just need to go out and tow and let the seat-of-your-pants feel and experience help you refine the setup. Don't get totally caught up in the numbers at this point.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 04-19-2016, 11:34 AM   #17
I just noticed the pro series wdh bars say 750lb max!! Now what??? :/
Old 04-19-2016, 11:39 AM   #18
AquaMan's Avatar
Again, how does it tow? If it tows well and feels good, not sure I would mess with it.
Old 04-19-2016, 12:41 PM   #19
rsdata's Avatar
I load a lot of stuff up front, but heavy items like my generator and bottled water/liquids and canned food I try to put over the axles. I would move some of your heavy stuff from the front further back over the axles to reduce your 1200# tongue weight. Your 750# rated bars could be traded in for 1000# bars at your dealer, but as others have said, if it tows well then it will be OK.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 04-19-2016, 02:42 PM   #20
Whats the door sticker have as GVW? Whats the driver side door post sticker Payload? Most of the get backs are right on - usually tongue weight is 10% (good idea to read manual about towing and hitch load).
DJsFolly
D. J. Schuler is offline   Reply With Quote
fuse
