Old 01-27-2016, 09:49 AM   #31
Kenny kustom's Avatar
It's a crock of bs.
I'm going to be close on payload.
So, either live with it, or take a bath, and trade my srw in for a drw.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-27-2016, 10:04 AM   #32
I'd certainly try it before taking said bath.
Karl4Cat is offline   Reply With Quote
Old 01-27-2016, 10:15 AM   #33
I do have to edit one number, I had thought my truck was 11.4 gvwr.
It is 11.7. ( 11.4 was my 350)
So in the end, I do have about 3200 for payload, with my fat butt in there.
2016 Sabre 36QBOK
Old 01-27-2016, 10:17 AM   #34
Seeing as there's 4 feet of snow outside, I have not installed the rails or wiring for the fifth. I know, it will tow just fine...
But, I've been the preacher of weights, so I can't go and be over!!!
2016 Sabre 36QBOK
Old 01-27-2016, 11:21 AM   #35
Helmsey's Avatar
Me, half(ish) tank of fuel in the truck in my sig, leaves me about 4200lbs of payload.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 01-27-2016, 11:22 AM   #36
drittal's Avatar
Curious what you door sticker says for available payload.
Reinforces my stance that 3/4t diesel isn't the right truck for anything above modest 5th wheels.
drittal is offline   Reply With Quote
Old 01-27-2016, 11:25 AM   #37
Fulltime family RVer
Kenny Kustom, clear out your PM box. I tried sending you another and it said you're full up.
Old 01-27-2016, 11:40 AM   #38
CWSWine's Avatar
I was reading the Ram specs and they are more confusing than Fords. But I did find that the max tow ratings they are using 15% pin weights.
I thought the max GVWR of 1 ton truck was limited to 11,500lbs but I see that Ram has much higher GVWR with some SRW 3500 have 12,300 lbs GVWR. Then using 15% pin weights you can get some very large tow ratings.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 01-27-2016, 11:42 AM   #39
3747
2016 Sabre 36QBOK
Old 01-27-2016, 11:42 AM   #40
Luck ducky.
F450.
2016 Sabre 36QBOK
