Old 07-27-2015, 01:27 PM   #1
leefl's Avatar
Kicking/Slipping with Reese Revolution in Reese Titan 16K hitch
Hi,
First time 5er owner.
I just picked up my new Rockwood UltraLite 8281WS at the weekend, towing with a new F250 with a Reese Titan 16K hitch, with the Reese Revolution unlocked, so as to use the Revolution's functionality.
I'm feeling some kicking when braking/accelerating after the first few miles.
It feels like the king pin is probably sliding back and forth in the jaw somewhat, though that's a little surprising since the Titan 16K has the dual serrated jaws.
When I picked up the 5er at the dealership they did have a little trouble getting the hitch lock to move into place at first (and I'm not completely sure what they did to resolve that).
Is there some adjustment to the Reese Titan hitch that I should be making to ensure that the jaws are tighter around the king-pin ?
Would better grease make a difference (the stuff they put on seems pretty poor) ?
The 5er has a fairly heavy pin-weight (for a "half ton towable") at near 1500lb, so I'm pretty sure it's not too light on the pin weight.
The 5er appears to be towing level (measured on a very slight incline, and the internal floor of the 5er seemed to be at exactly the same fractional slope as the road).
I haven't yet checked the level of the truck when towing. Unladen the back of the bed is higher than the front by about 2" and the back definitely dropped at least a couple of inches when towing, but it looked reasonably level (just by eye).
Any suggestions or recommendations would be greatly appreciated.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 07-27-2015, 02:08 PM   #2
dcheatwood's Avatar
You can adjust for fit by hooking up, loosen the wedge bolts, slooowly pull forward with trailer brakes on. This puts the pin tight against the jaws.
Now park and get out without allowing truck to move forward. (Emergency brakes on.) Push wedge plate as far forward as you can. Tighten and torque per owner's papers in TT manual pack.
This takes some play out of the hitch by moving the wedge as tight as you can.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-27-2015, 02:25 PM   #3
leefl's Avatar
Originally Posted by dcheatwood View Post
You can adjust for fit by hooking up, loosen the wedge bolts, slooowly back up with trailer brakes on. This puts the pin in the forward most part of the hitch.
Interesting suggestion, however I'd have thought that pushing the wedge forwards towards the king pin would effectively be pulling the king-pin back towards the rear of the TV, so you'd want to hitch up, lock the hitch jaws, pull forward slightly to pull the king ping against the back of the jaws, then push the wedge plate in fully to hold it there, and stop it sliding towards the front of the TV when braking.
That way the wedge plate should in theory stop the king pin moving forward towards the front of the truck when braking. (however I'm not sure how much load I'd expect the wedge plate to take without moving, even when properly torqued).
The initial Revolution setup was done entirely by the RV dealership, so I might have to double-check the adjustment and torque myself.
(they did make a mess out of the locking bolts when removing them, not that I plan on ever using them again, but it looks like they used the wrong socket for removing them so that they got chewed up ... not confidence inspiring)
Alternatively, is there any way to adjust the hitch to just close the jaws tighter ?
Old 07-27-2015, 03:30 PM   #4
dcheatwood's Avatar
Yes. I tried to remember from reading this 2 years ago. You have the idea right. Take the slack out. I have Reese 16 k hitch and never heard of adjusting the jaws. Good luck.
Old 07-27-2015, 03:33 PM   #5
dcheatwood's Avatar
My wedge worked loose after dealer install and I had to reset and torque it after a few trips.
Old 07-27-2015, 08:31 PM   #6
leefl's Avatar
I'll be heading out for a "local" (160 mile) trip on Thursday, so I'll head over to the storage place early and try to adjust the hitch/wedge then, before bringing the 5er home and then heading out.
Old 07-27-2015, 09:16 PM   #7
dcheatwood's Avatar
Good. Report back so we know if it helped any.
Old 07-28-2015, 09:21 AM   #8
NVHD-10K22SW.pdfThis may help
2014 Ram 2500 Bighorn CC SB CTD 4X4
2016 Flagstaff 8528IKWS Platinum
2013 Keystone Hideout 23RBWE -Sold
randygk is offline   Reply With Quote
Old 07-28-2015, 02:21 PM   #9
pontiacdan45's Avatar
Send a message via Skype™ to pontiacdan45
Suggest that you watch the on line video on the Reece. I shows how to install the wedge and tork it correctly. I had a lot of issues with mine because of my experience level. None. But eventully I learned to make sure the pin box was straight and that a little grease on the wedge edges and on the pin box plate and hitch would allow a good connection. Also, it there is the least amount of tension between the truck and 5er when you unhitch it won't work until you back into the pin box tightly and then apply the brake to hold it until someone can pull the pin. Is the kicking and slipping due to the bias on the trailer brakes?
Pontiac Dan
2015 Rockwood Signature Ultra-Lite 8289 ws
2015 GMC Crew Cab 2500HD Gas:
pontiacdan45 is offline   Reply With Quote
Old 07-28-2015, 03:14 PM   #10
leefl's Avatar
Originally Posted by pontiacdan45 View Post
Suggest that you watch the on line video on the Reece. I shows how to install the wedge and tork it correctly. I had a lot of issues with mine because of my experience level. None. But eventully I learned to make sure the pin box was straight and that a little grease on the wedge edges and on the pin box plate and hitch would allow a go od connection. Also, it there is the least amount of tension between the truck and 5er when you unhitch it won't work until you back into the pin box tightly and then apply the brake to hold it until someone can pull the pin. Is the kicking and slipping due to the bias on the trailer brakes?
That's certainly possible. I didn't have much issue adjusting the brakes on my old pop-up, but the F250 had two settings, bias and force.
I didn't seem to be getting much braking force from the 5er, so I adjusted the force from low to medium, but left the bias at the default of 10.
Since it kicks slightly when braking, and again when pulling away, it seems like the truck must be out-braking the 5er, which would mean that is need to increase it more, and the bias is at max (unless the bias number means the inverse of what would seem logical to me)
hitch
