Old 06-21-2011, 06:33 PM   #1
cmhbob's Avatar
King pin/axle Alignment
Our first hitch was a Reese Pro Series 15K. I tried to hook up one day with it closed, and bent it all to crap. A nearby RV shop sold me a used Husky 16K S hitch for $400.
When we hooked up with the Reese, I could open and close the both the pickup gate and the forward cargo hatch, even while hooked up. I can't do that now, as the rig is about an inch farther forward toward the truck than it was on the Reese. The pin is about 1 or so in front of the axle, but there's another set of holes on the back part of the hitch A-frame so I can move it if it should be moved.
My question then is where is the kingpin supposed to be in relation to the axle? Directly over it? A little forward? I didn't notice where it rode on the Reese, and I'm not sure I can feel any major difference between the two hitches in the way it pulls. I'm considering moving the hitch back so we can gain better access to the cargo compartment, but not at the risk of screwing up the weight distribution.
Bob Mueller | Fulltiming family of 9 since Feb 2011
More About Me
cmhbob is offline   Reply With Quote
Old 06-21-2011, 07:55 PM   #2
M109Rrider's Avatar
Right over the axle is what I was taught.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 06-21-2011, 08:02 PM   #3
I was always told just forward of the axle to put a lil weight forward
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 06-21-2011, 09:45 PM   #4
It is supposed to be a bit forward for weight distribution and for stability in an emergency evasive manouver. But you could probably get away with it directly over the axle. Just make sure it isn't even a fraction of an inch behind.
Old 06-21-2011, 10:43 PM   #5
froggy's Avatar
Reese installation calls for the king pin 'directly over' the axle.
Forest River, Palomino, 2010 Sabre 31 RETS
2010 Dodge Ram 3500 ST Crew Cab 4X4, 6.7 Cummings Turbo Diesel, SRW, Short Bed, Reece 15K Slider Hitch
froggy is offline   Reply With Quote
alignment, axle
