Old 05-13-2012, 08:59 PM   #1
Lacrosse 318
i currently have a tundra with a towing capcity of 9700lbs and a payload of 1355, i am looking at buying a Lacrosse 318 but the sales person informed me that i should have a cargo capicty around 1500-1600lbs. so my question is is my truck able to handle this trailer, and the other question is how does the cargo capacity affect the towing of a trailer
Thanks Eli
eduvall79 is offline   Reply With Quote
Old 05-13-2012, 09:22 PM   #2
tbritt's Avatar
Thanks Eli
I know how you Tundra guys are!! But I just completed a 5600 mile trip with a 303RK with a 07 Nissan Titan and had no trouble. Have fun and enjoy.
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 05-14-2012, 08:48 PM   #3
I pull the Lacrosse 318 with my Tundra with no problem. I put very little in the bed of the truck. If your wd hitch is set up properly and pack the bed light. You will have no problem. Do you have crew max with 5.7? I also have the TRD package. Little stiffer suspension that probably helps.
Enjoy your 318. We absolutely love ours and I'm sure you will too. Happy Camping!
2008 Toyota Tundra TRD 5.7
2013 Lacrosse 318 BHS
jjumpoh is offline   Reply With Quote
Old 05-14-2012, 10:09 PM   #4
weiman1983's Avatar
Send a message via Skype™ to weiman1983
I tow my 318 with my F150 without any issues. My truck has the same towing capacity. Only difference is that the payload is a little higher. I agree that if you pack the bed light you will be fine.
weiman1983 is offline   Reply With Quote
Old 05-15-2012, 05:22 AM   #5
awesome, i have a double can 5.7l SR5, i was a little worried that i may not be able to tow the trailer because the sales person told my i should have around 1500 - 1600 payload i believe if i take 1-% of the trailer weight i should get my should get my cargo capacity, which is 780lbs, which still gives me about 400-500lbs.
the sales pers said with your family in the truck and then a full tank of fuel would take away from that. i'd assume the payload incorporates a full tank of fuel?
Old 05-15-2012, 06:14 AM   #6
cstover's Avatar
Payload assumes full tank of gas and 150lb driver. Nothing else.
cstover is offline   Reply With Quote
Old 05-15-2012, 06:32 AM   #7
awesome that what i figured thanks alot...
How many campers out their actually use their box to store stuff, because it seems like the travel trailers have more then enough
Old 05-15-2012, 11:45 AM   #8
cstover's Avatar
I use mine for my cooler.
Old 05-15-2012, 09:01 PM   #9
Your dealer is correct. You will almost certainly be over your GVW. Can your truck pull it, absolutely. Is there liability exceeding your GVW, absolutely.
2012 Lacrosse 318BHS
2010 F-150 Max Tow
21C1 is offline   Reply With Quote
Old 05-22-2012, 03:20 PM   #10
Just wondering as I read this, how could anyone think that you could pull a 5er with a 1,600 lb truck payload? I got a new 2012 V-Cross 275 5er that has an empty weight of 7,791 lbs(actual) and weight rating of 9,850 lbs. The pin weight will be about 1,950 lbs, which is more then the listed payload. Yet the sales paper states that it is 1/2 ton towable? Sure glad I have a 2011, F250, diesel, CC, long bed SRW.
whj77372 is offline   Reply With Quote
