Old 01-12-2019, 11:46 AM   #1
LED Extra Lighting
I was thinking of adding some LED lighting to the rear for back up at night. I was also looking at some for the front for foggy or off road extra lighting.
Does anyone have any advice in this area? What type system is best for the money? Any advice would be appreciated.
I have a Ram Bighorn 3500 Short Bed. I do have two batteries and alternators.
MikeRP is offline   Reply With Quote
Old 01-12-2019, 12:46 PM   #2
clarkbre's Avatar
Best for the money is 2 18w LEDs mounted under the bumper and reverse wired to a double throw single pole switch. The switch can make them come on automatically with the reverse lights or manually turned on for accessory lighting.
For the front, even a 10" lightbar will light the road quite nice. i had one behind the grill in my F150 and used it often on rural roads and highways.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 01-12-2019, 12:59 PM   #3
Any recommendations on make and model of the led lights?
Old 01-12-2019, 01:39 PM   #4
I put AutoStore bumper mounted LED fog lights on the back bumper of my trailer for backup lights. They'll work fine as extra backup lights on a truck. I've pointed them slightly to the side for wider illumination rather than straight back.
On the tow vehicle I swapped the OEM backup light bulbs for much brighter LEDs.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 01-12-2019, 01:44 PM   #5
clarkbre's Avatar
Here's the 18w reverse lights that are sold in a pair:
YITAMOTOR LED Light Bar 2PCS 18W 6 Inch Flood LED Work Light Pods Single Row Off Road Led Light Driving Light Fog Light Boat Light Waterproof SUV ATV 4WD Car Truck Golf Cart 12V 24V, 2 Year Warranty https://www.amazon.com/dp/B01A6TNWHW..._VuJoCbA6PTFA8
Old 01-12-2019, 09:59 PM   #6
Fishtexx's Avatar
Added these LED's in my rear bumper, hooked them up to my up fitter switches. Makes plenty of extra light. Same with the front.
ID:	194472   Click image for larger version
Terry and Laurie
2017 Flagstaff 27RLWS
2018 F-250 6.7 4X4 Crew
Fishtexx is offline   Reply With Quote
Old 01-12-2019, 10:06 PM   #7
Tractor supply or any of your local truck accessory stores will have some nice thing about the later is they can walk you thru what you want and offer installation if you need it
moose074 is offline   Reply With Quote
Old 01-12-2019, 10:11 PM   #8
Nice I like those bumper mount ones!
Old 01-12-2019, 10:19 PM   #9
clarkbre's Avatar
I like them a lot too. My brother has them on hos RAM and it's a nice set up.
I honestly just can't bring myself to cutting holes in the factory bumper. I did find some light mount brackets that are a bolt on application. The lights sit just under the bumper bit are protected by the trailer hitch.
Old 01-12-2019, 10:25 PM   #10
Fishtexx's Avatar
Measure twice, cut once. Also sprayed a rust preventative prior to bolting the lights in. Actually, I think I measured about 6 times! LOL
Terry and Laurie
led, light
