Old 03-13-2019, 12:48 PM   #1
LED highlights
Has anyone modified there OEM vehicle headlights to LED? I want to put brighter headlights on my Silverado. I was at the dealership this morning and they told me it was a safety issue and they could not install the LED headlights
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 03-13-2019, 01:00 PM   #2
007matman's Avatar
I put a set in my F-350.
Best money I've spent (outside of the Bullet-Proof).
Really helps. They put the LED's in the same place as Halogen and have little fans to keep them cool. Light is much better
These are the ones I went with.
HIKARI Ultra LED Headlight Bulbs Conversion Kit -H13/9008, Prime LED 12000lm 6K Cool White,2 Yr Warranty https://www.amazon.com/dp/B07D7TFM9Y..._4suICb4HCXMT8
007matman is offline   Reply With Quote
Old 03-13-2019, 01:02 PM   #3
Broken Toe
Cowracer's Avatar
I put LED's in my side-by-side. Very easy to do. Well worth the $$$.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 03-13-2019, 02:27 PM   #4
Did you hire a shop or do it yourself
Old 03-13-2019, 03:00 PM   #5
007matman's Avatar
I don't know who you're asking.
It's just a bulb replacement. You can do it yourself. Just make sure you're getting the correct size.
Typically, the OEM housing comes out either with screws or with pins. Turn the socket to release the bulb, disconnect the wires and the opposite for install.
My truck has four screws and it probably took me 10 min to do both sides.
Old 03-13-2019, 03:05 PM   #6
007matman's Avatar
Ok.. it's a little more involved for your truck but here is a step by step video.
Doesn't look too difficult.
https://youtu.be/1oKyanoXa70
Old 03-13-2019, 03:09 PM   #7
Broken Toe
Cowracer's Avatar
This is kit I used. They are for a 9008 number bulb.
click here
They plug right in like a standard halogen bulb. If you can change your bulbs, you can put these in. There is a small "power pack" that you zip-tie somewhere out of the way. Your headlight plug plugs into the power pack, the cable from the power pack goes to the new bulb. easy-peesy.
Literal "night and day" difference.
Tim
2016
Rallies Attended:
Old 03-13-2019, 03:15 PM   #8
007matman's Avatar
Looks like your truck may be an H11 size.
I would look it up first.
Old 03-13-2019, 03:29 PM   #9
Lins's Avatar
The dealership likely wouldn't do it as it's technically illegal to use a different type of bulb. A lot of dealerships do and they'll know what works best. Check the GM forums to see what works well in your type of headlight. For the Rams, HID works best in the projector style headlights and LED in the reflector style. If you do it opposite you get a lot of glare which is dangerous and annoying for other drivers.
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is offline   Reply With Quote
Old 03-13-2019, 03:39 PM   #10
Could you explain how it's illegal you use a different bulb? makes no sense to me . they have had kits and up grades for bulbs for yrs , different lenses , etc don't see where it's illegal
MR.M is offline   Reply With Quote
led, light
