09-30-2014, 07:41 AM
#1481
Originally Posted by BigBaron
So what was the reason for the upgrades and what is the end benefit performance-wise?
The Afe Bladerunner intake manifold ($369) provides lower EGT's, improved MPG and faster turbo spool up times, which outflows the factory manifold unit by 18%, the Riffraff turbo wheel ($195) provides anti-surge and a 5 to 7 pound gain in boost pressure along with an average of 17.4 hp and 38.7tq gain on stock injectors. I'm seeing a very fast spool up of my turbo now and I don't have any more surge issues that I used to have. The new turbo up-pipes ($250) on my truck were worn out and leaking badly so I replaced those which will also help regain my boost press. and lower my exhaust gas temps., the factory intercooler boots were worn out and leaking turbo boost so the new Riffraff CAC blue intercooler boots ($128) were installed along with RDP Plenum Reinforcing Inserts ($39) to keep from crushing the intake collars when torquing the clamps down on the boots. While I had the turbo off I rebuilt the turbo pedestal EBPV (exhaust back pressure valve) because it had 133,000 miles on it and replace upper and lower pedestal o-rings also. The new Riffraff cold air intake ($87) just lets the motor get all the air it wants and filters the intake air very well at the same time and looks cool also. I replaced the altenator ($200) because the main wire was cooking off at the altenator and didn't want any failures from it on the road, just a little insurance. The larger transmissioin cooler ($250) was needed because Ford undersized the tranny cooler for towing these large loads pushing GVWR's so I installed the tranny cooler that goes in the 6.0L engine which is 3.77 times larger. Before the larger cooler install my tranny temp hit 228 deg. this summer a couple times which isn't good and now after the install of the larger cooler and towing up and down hills I haven't seen the temp get over 184 deg. on the tranny. Unloaded the temp stays at 138 to 140 deg. Just did the upgrades to the old truck so he can tow this 16,000 pounds of toys down the road without any issues. My 5er toy hauler is 13K empty and loaded with our things and a Canam Commander 1000 in the back its about 16K lbs. My next mod is to add a 5th wheel safety latch incase the pin latch ever comes loose the 5er won't come off the truck and do any damage, just another insurance policy. I've never had any issues in that department and I don't want to either and for $85 with shipping it is a cheep insuance policy. I'm ordering it today. Hope that helps with the benifits I installed. It did make a big difference towing our last time out, it stayed alot cooler, had more power and seemed like a rejuvenated truck all around proformance wise. I think I also will be replacing the fuel injectors one of these days with some stage 2 injectors but I'm happy with the old trucks performance for now with these upgrades. This project took me about 30 to 40 hours of my time because I went a little slow and did some other things along the way while I had it all apart like cleaning the fuel return valve and putting in a new fuel pressure spring in it to keep the fuel pressure between 62 to 65 lbs., cleaned the fuel filter housing and installed all new o-rings in it, dropped the fuel tank and removed the fuel sending unit and cleaned the strainers and reinstalled. They were pretty dirty. It was well worth my time since owning this truck new and never having to do a thing to it except regular maintanence items. Feels like a new truck again!!!
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
09-30-2014, 08:00 AM
#1482
Originally Posted by f1100turbo
I just did similar upgrades on my duramax.
Mpg went up from 17-18 mpg to 21 mpg.
Towing mode adds 30 hp over stock.
Lower egt's
Dpf filter delete.
Catalytic converter delete.
Egr delete.
Efi live tuned
Optimized stock
30 hp on heavy tow
60 hp on light tow
90 hp Economy towing
120 hp street
Turbs
Sounds good f1100turbo.
I also did the intake air heater delete and already had put on a 4" stainless exhaust years ago. I have the Edge Evolution tunes I just keep it on stage one safety tow of 60HP. I have a new Garrett turbo non-EBPV pedestal but didn't put it on because I forgot to order the Garrett high flow outlet. I did calibrate the EBPV after rebuilding it and the turbo waste gate during reassembly. I haven't checked my mileage because all I do with the truck is tow and it gets 9 to 10.5 depending on the hills, I have a Ford Fusion I drive for a dayly driver it gets 30mpg. I'll have to check my trucks fuel mileage now with these up grades and see if its any better but even if its a 1/2mpg better I'd be supprised. LOL
09-30-2014, 08:06 AM
#1483
I'm also at 4" from down pipe to the muffler.
I left the stock muffler and tailpipe for noise considerations.
I'm leary of deleting heater as I live in a cold climate.
Turbs
09-30-2014, 08:14 AM
#1484
Turbs
I hear you, here in Texas we don't have much winter so I didn't mind doing the intake air delete and leaving in the EBPV helps to warm up the engine and my truck uses it in the colder days to warm up so I didn't mind just rebuilding it that way my truck can still warm up without sitting there forever to do it. What truck do you have?
09-30-2014, 08:16 AM
#1485
08 lmm duramax.
Turbs
09-30-2014, 08:19 AM
#1486
nice truck
09-30-2014, 08:20 AM
#1487
nice truck
Ty
Turbs
09-30-2014, 08:24 AM
#1488
nice truck
X2, but I want the garage!
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
09-30-2014, 08:41 AM
#1489
09-30-2014, 09:48 PM
#1490
Aggie Family
2014 F150 Ecoboost 157" Wheelbase, 3.73 rear-end
Aggie Family
2015 Rockwood 2618W, 2-A/Cs 50 Amp
2014 F150 Ecoboost, S-CREW 157" WB, 6.5' box, Tow Mirrors, Maxtow, 3.73
Equalizer 4-pt WDH
10-01-2014, 09:10 AM
#1491
Incheon, S. Korea
Mud Yapster and Turbs - I think I'm gonna have to get a truck just so I can have somethin' to fiddle with!
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
10-01-2014, 04:47 PM
#1492
phat phrog stunt crew
turbs .... has that extra stuff thrown any cel's or anything? i wouldnt mind doing the intake exhaust type stuff, but am kind of leery about putting a tuner to mine. mine is out of warranty, so thats 1 less thing to worry about. who did you go through for all your other upgrades?
Sent from ny nook using fairly accurate digits.
10-03-2014, 10:20 AM
#1493
Heading out to Cookeville, Tennessee for the latest rally ....
White 2016 Work & Play Ultra 25ULA, Cherry Wood, Pebble, Onboard Onan 5.5, Onboard Fuel Station, 50-Amp Service Onyx Black 2015 Chevrolet Silverado 2500HD DCSB, 6.6 Duramax/Allison, LTZ/Z71 397bhp/765t Black Raven 2015 Cadillac Escalade Premium 420 bhp/460t Merlot Sunglo 2011 Harley Davidson Street Glide FLHX, FM 107", PM Heathens 21"/17", Metzeler ME880's (200 Rear), CVO Rear, Chain Drive 116rwhp/127rwt
10-03-2014, 11:50 AM
#1494
Old Enough to Know Better
Here is my old rig and its new replacement
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
10-03-2014, 12:44 PM
#1495
Nice upgrade!
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
10-03-2014, 12:47 PM
#1496
Thanks I like it, But it seems to be bigger than the old one. I know there is only 4 inches difference in wheel base but wow
10-03-2014, 01:49 PM
#1497
Camper Less Camping
Literally a night & day difference...looks good!!!
2013 Sabre 32RCTS-6 (sold)
10-03-2014, 05:37 PM
#1498
Motor Ops Autocal? That's what I have but have not deleted yet so I can add those tunes downtown the road. I still have 80k of warranty for now.
Lower egt's
Dpf filter delete.
Egr delete.
Efi live tuned
Optimized stock
30 hp on heavy tow
60 hp on light tow
120 hp street
Turbs
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
10-03-2014, 05:47 PM
#1499
Originally Posted by BrianSF-GA
Very nice!! Have a great trip!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
10-10-2014, 09:03 PM
#1500
My rig.
Tried uploading the jpg and a link, not working. Using an iPad air.
http://www.forestriverforums.com/att...f083381e0.html
2015 Sandpiper 30IOK
2019 GMC 2500HD 6.6 Duramax
