03-27-2019, 11:53 AM
Let's talk bed liners
Ok all I have a question. I'm going to do a spray in bed liner. Jury's still out on line x or rhino. Those who have either please give advice. I'm looking for hardness and how it looks after afew years in the sun. Also I want to spray my hitch rails. Pros cons of doing this. I have a B and W patriot
03-27-2019, 11:58 AM
I've had both and my preference is Line-X.
Both cost almost the same with almost exactly the same thickness in coating but I felt the Line-X guys did a better prep job and I felt the liner looked better after a year or two.
If you spray the hitch rails, (I did in one truck) mask off the area where the hitch sets. Otherwise you won't get the pins in.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
03-27-2019, 12:05 PM
Did you think the line x was harder when it cured
03-27-2019, 12:13 PM
I don't know if it was 'harder,' it just wore/looked better.
03-27-2019, 12:15 PM
Enjoying Life
I had the line-x on a previous vehicle. When I sold it after 14 years it still looked like new.
2022 Rockwood 2109S
Previous: Rockwood 2608WS, 2608BSD
2006 Durango HEMI
03-27-2019, 12:16 PM
I also had Line-X and Rhino. I'll say the Line-X did wear better and looked better after a couple years of abuse.
03-27-2019, 12:34 PM
I've had Line-X for almost three years. Looks brand new. Also, I believe Line-X comes in many more colors (at least it did when I had mine done).
I have friends with both. The Line-X does look better after a few years. That is what drove me to choose Line-X.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
03-27-2019, 12:42 PM
If you have a cap, a BedRug is the way to go.
I hear the BR works great in open bed truck though..either way its a great bed liner.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
03-27-2019, 01:02 PM
I have a 2018 F150, choice between spray on or drop in bed liner. The fact the Ford has an aluminum box I chose a drop in bed liner because I will have no corrosion issues and it adds strength to the bed. However my previous 2013 F150 had a drop in liner which trapped moisture beneath it and rotted out the bed floor. I had my 1974 F250 sprayed and never had a problem with it.. NO rust corrosion. So bottom line if you have a steel box a spray in liner is best. Aluminum box drop in liner is best.
Hope this helps Cheers.
03-27-2019, 01:03 PM
Box liners
03-27-2019, 01:06 PM
Never heard of it. Just looked it up. Does it work with a 5th wheel hitch? Also i slide allot of things into my bed. Can u slide items across it
03-27-2019, 01:08 PM
Sorry... I can't comment on your two options since my last two have been Super Liner. They have worn well.
03-27-2019, 01:09 PM
My Line-X looks new after 7 years. I'd remove the rails and have them done separately.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
03-27-2019, 01:11 PM
Line X is better than Rhino. I find Rhino looks worn and dull after a while.
I had a local dealer put in a Reflex Liner. This tougher than Line X and can be tinted too.
03-27-2019, 01:12 PM
It's rugged and impervious to fluids and liquid.
To make it fit with a 5th wheel hitch, you would either cut it around the hitch or mount the hitch through the Bed Rug. The latter would make a cleaner install.
03-27-2019, 01:36 PM
X2, I prefer Line-X.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
03-27-2019, 01:37 PM
I've had both, and went with Line X in the new truck. I liked the texture better than the old Rhino liner that I had in a previous vehicle.
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
03-27-2019, 01:39 PM
Kanadian Kamper
I'll say the Line-X did wear better and looked better after a couple years of abuse.[/QUOTE]
Wish I could say the same about myself, but my wife’s a little rough.
Ken and Terry
03-27-2019, 01:52 PM
I had a dealer-supplied spray-in bed liner in my 2011 F150, but I dropped in a GMC bedliner in my 2015 Sierra, and I now have a tonneau cover. Two reasons: I did not particularly line the look of the spray-in after a few years, and also sap from softwood logs stained the sprayed-in liner. However, I do not like the fit of the drop-in alternative, especially the fit along the side walls. I would still go drop-in again, but I would look for the best fit alternative.
03-27-2019, 02:01 PM
I bought the factory spray in liner with my F-150 bed. What is great about it is that is preserves all the drains around the front and rear edges of the bed and every screw everywhere is put in after the liner is sprayed in. Is absolutely perfect.
The factory spray in is very similar to line-x.
I would never buy a drop in liner.
