06-29-2018, 01:46 PM
#21
[The Equalizer is much better. I feel a little sway in side wind when driving over 65. But nothing from trucks. My only complaint with Equalizer is the noise when turning.[/QUOTE]
As 007matman said, and I use them also, get the pads that slip on over the L brackets. I use the blue lube also.
06-29-2018, 02:36 PM
#22
To the OP..
I feel.for you man. I think we're in a similar situation. My Eaky would pull the camper just fine but I was on the edge of capacity and slightly over with all 4 kids, luggage, etc.
We just bought the camper a little over a year ago and sold our old PUP so I'm kinda stuck with what I have now.
I also have a son starting college this year and couldn't afford to buy a new vehicle.
After many months of torturing myself over the decision to purchase the larger camper (which we needed) I made the decision to upgrade the TV. We still have the Esky (which I might sell to rid ourselves of some debt) but the F-350 CC Dually was made to pull that camper. Seats 6 just fine.
I was having issues with tire wear, shocks, transmission, overheating (getting hot), etc. That's why I abandoned towing with it. I didn't want to blow it up. It would pull all day but I could tell it was hard on it.
Sent from my Pixel 2 XL using Tapatalk
06-29-2018, 02:50 PM
#23
Originally Posted by txredfish
About 10 years ago, I had a Reese WD setup like yours. I now use an Equalizer. I now have a different trailer (but close to same weight) than that was used with the Reese but I can really tell the difference. The Equalizer is much better. I feel a little sway in side wind when driving over 65. But nothing from trucks. My only complaint with Equalizer is the noise when turning.
That's why I was leaning toward the Anderson, but I'm not sure now.
#24
I have a Grey Wolf 23MK and an Andersen hitch. Works fine, no sway, transfers weight great to my 1500 Ram pickup. TT is about 5500 empty, GVW is about 7600. Actual tongue weight is around 700 loaded for me (I weighed it). I'm happy with the Andersen.
06-29-2018, 02:55 PM
#25
Originally Posted by maskins
Had not seen that... I like it, and probably much quieter
#26
I have the Hensley system and love it. It was a little pricey, but you get what you pay for. Since having it, I have eliminated sway, had better control of the trailer, and better over-all enjoyment while pulling my TT.
Sent from my VS995 using Forest River Forums mobile app
06-29-2018, 03:00 PM
#27
Originally Posted by Idrive4fun
Why? Trailer is about 6000/8000, (never been to 8000) truck is 9000+, yes it has a little squat, which is one reason why in looking for a different setup. If not much wind, it tires fine, even with semis around. But it is loud, and with too much side wind, it wiggles a little. The loud is another reason.
My apologies. I would of never guessed a rating that large on a vehicle that size. Pictured with the camper it looks like a small suv towing a beast
06-29-2018, 03:57 PM
#28
Hitch
Nothing helps sway like a longer wheelbase, heavier truch.
06-29-2018, 04:21 PM
#29
https://www.hensleymfg.com/
Don’t try to control sway just eliminate it, you might think this is pricey, I had mine for 20 years and when I switch to a fifth wheel I bought one of theirs, I was able to trade in my old one which gave me 50% off and basically I got as much back trading it as I had paid for it 20 years ago. These are just unbelievable, my last hook up was a 30 ft surveyor hitched to a Volkswagen Touareg diesel.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
06-29-2018, 05:05 PM
#30
Kimber45- That's OK. I do need to keep thinks like that in mind. It is an Expedition, so based on the 150 chassis. Still squats more than I like tho. Especially coming from a 350 to this (no sway on that dually!)
I am appreciating everyone's advice! I really wish that I could try out these hitches to see which one works best for me. A shame to spend $400+ on something that doesn't do anything more than what I have.
06-29-2018, 05:38 PM
#31
Ham Call N8SAC
If that’s your set up you have equalizer set up with no sway control. You need a twin cam set up to. Stop by your local dealer and have them explain what a sway control does. Used Reesetwin cam for years with a 23’ RV . Worked good.
06-29-2018, 06:49 PM
#32
Just as confused as you
You better go back and read OP's original post and look at the attached pics. OP has a reese with 2 friction sway controls that connects to the trailer tongue. Like someone said in a earlier post, OP needs to take it to a scale and see what his real weights are. He may just have to do a little more adjustments. In the pics his bars seem to have too much curve in them and the TV does look a little low in the back and high in the front and the trailer does look to be low at the front. He wants the trailer frame as level as possible with no more than 1 to 2 inches lower in the front. It looks as he has more than that. Though I may be wrong, it's just my opinion based on what I see in the pics and what the OP says in his posts.
Richard & Jill
06-29-2018, 07:59 PM
#33
Has the sway brakes. One on each side. But I like the cams... I am looking at them.
06-29-2018, 08:05 PM
#34
Scraper- yeah, the setup on this hitch was originally for my f-350, and I moved it to this SUV when I sold the truck. I know it needs adjusted, but not sure what to do. Hence I'm here. Thought I needed a new hitch, but I'm liking the cams from Reese.
06-29-2018, 11:13 PM
#35
I Have a Husky Centerline TS with 1200k bars (they make bars for different weights) and love it!!! I have a Cherokee 274VFK @8500 pushing a Ram 2500 long bed. I can drive at 75 if wanted (rarely over 65 for MPG) and have NO sway problems, I can drive with one hand and not feel anything when passed by trucks. Different set up yes but with proper Husky for your rig I think you would be happy.
TV: 2014 Ram 2500 Laramie Longhorn
TT: 2018 Cherokee 274 VFK
Husky Centerline TS 1200
06-30-2018, 03:36 AM
#36
Just a member
Ditto! Eighth season and 40K kms with a Reese Dual Cam setup. Quite simply, it works!
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
06-30-2018, 04:54 AM
#37
Equal-i-zer is a brand of WDH that has integrated sway control.
the OP has a Reese WDH, not an Equal-i-zer.
06-30-2018, 05:42 AM
#38
NOTICE to the OP You CAN'T just Add the "Dual Cam" to YOUR Reese ROUND Bar Setup!!! Your ROUND Bars have NO "CAM Depressions" to fit the Cams!! You will have to know what Size # Bars you Need then see if REESE makes "Round Bars that Fit your Head" for "Dual Cam Use"! You MAY need to go with "Trunnion Type Head and Bars"? I just want you to be aware that "LOTs" of things DON'T interchange!! Youroo!! You May check to see if "Round Bar Reese Part # 58115 fits Your Head" if so they are for Dual Cam and cover "800-1200#" TW!
06-30-2018, 06:25 AM
#39
X2
Sent from my SM-G950U using Forest River Forums mobile app
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
06-30-2018, 06:33 AM
#40
Youroo is right! I had to scroll back and look.
I have a trunion 1200lb reese, and was able to add the cans, after checking with reese to be certain.
The OP pictures are straight round bars and would need to be replaced.
My guess it's nearly a do over. But reese's straight line setup has been good with me. Just had a 400 m run and no issues.
2004 Ram Quad 1500
1986 Jayco1016PUP
