Old 07-28-2019, 06:58 PM   #1
Leveling 2008 sierra f255 for new 2019 F350
I take delivery of a 2019 F350 on this week, replacing my 2012 f150 TV for my 25' Sierra 5th wheel. I didn't think about the height difference (not a smart move, I know), and expect to be nose high with the new truck (it's noticibly higher, as expected). My hitch is as low as it will go, and the trailer axles are in the lowest shackle holes and are already under the spring with a spacer. Short of a new trailer, what is the best way to get everything level? It fit perfectly with my f150. Thanks
Macgyver709210 is offline   Reply With Quote
Old 07-28-2019, 08:44 PM   #2
I want from a Nissan frontier to a Ram 2500 and had to use 9" drop shank to get level.
upflying is offline   Reply With Quote
Old 07-28-2019, 09:03 PM   #3
2008 sierra f255 on 2012 F150
This is how it looks on my F150
Old 07-29-2019, 09:04 AM   #4
Grammar Pedant
67L48's Avatar
I've read where some will swap out the rear blocks for something shorter (e.g., 4" factory blocks to 2" blocks). Another guy had an entire suspension overhaul to lower his truck ... essentially the reverse of a quality lift kit. Most people seem to just shrug and live with being a bit nose high. Do some searching over at a Ford SD forum for some additional ideas.
I'd wait to see how it all comes together after you get your new F-350 ... and then go from there.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 07-29-2019, 09:14 AM   #5
Thanks 67L48
I can probably live with being nose high, as long as I don't lose my rear legs. I'm getting the hitch moved over to the new truck today, so I'll see what they have to say
Old 07-29-2019, 02:36 PM   #6
Originally Posted by Macgyver709210 View Post
Thanks 67L48
Does your trailer have leaf spring axles or torsion axles?
2019 Silverado LTZ 1500 6.2L 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 3.42
2015 Jeep Wrangler Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 07-29-2019, 02:48 PM   #7
It has leaf springs. I can take a pic tonight, if you like.
Old 07-29-2019, 04:06 PM   #8
5th wheel
The OP has a Sierra 25' 5th wheel. Do 5th wheel pin boxes use a drop shank?
Larry
Larry-NC is offline   Reply With Quote
Old 07-29-2019, 06:38 PM   #9
justpassinthru's Avatar
Leveling
Hi question. Doesnít your hitch adjust in height. My Curt Q20 slider has several height adjustments. Thanks
justpassinthru is offline   Reply With Quote
Old 07-29-2019, 07:07 PM   #10
Tundra 2014
F-350 SD
You might check w/ Lippert if they have a lift kit for your 5 th. wheel frame after trying w/ new truck. I also have a new SD F-350. Currently pulling a TT but, planning to switch to 5 th. wheel in the future. Will be following to see what works for you.
Tundra 2014 is offline   Reply With Quote
Old 07-29-2019, 08:02 PM   #11
justpassinthru, it does, but not enough to help . It can only go down 1 inch and the pin can go up 2, but than I have less than 6" clearance between the top of the box, and the trailer.
Thanks though
Old 07-29-2019, 08:07 PM   #12
Tundra 2014, Thanks. I'll have a look and let you know how it goes.
Old 07-29-2019, 08:58 PM   #13
CaptnJohn's Avatar
Thanks though
I have an F350 4x4 diesel. This and last 5er were at 4 3/4 to 5Ē and never a problem. Next week my new dually arrives and not sure what Iíll get into for heights either.
Old 07-29-2019, 09:40 PM   #14
Thanks CaptnJohn
That's good to know.
Old 07-29-2019, 09:53 PM   #15
I am running in 4x4 Dually. I know I am longer and heavier but I tow pretty level. Even though the payload is near double on the Dually than on my swd I felt I squatted just as much. I actually use aircells to stay up higher in rear
moose074 is offline   Reply With Quote
Old 07-29-2019, 10:49 PM   #16
No need. Leaf spring setups can be towed unevenly, although it's not necessarily recommended.
2020 KZ 130RBSE
Old 07-30-2019, 07:26 AM   #17
Thanks. The hitch guy said the only problem is that the rear wheels will wear faster.
Old 07-30-2019, 07:27 AM   #18
Thanks.
Old 08-01-2019, 06:56 PM   #19
Thanks for all the advice. The hitch guy said he can make some adjustments I'll post an update after my first trip.
Old 08-15-2019, 06:21 PM   #20
The hitch shop was able to get it almost perfect by adjusting the hitch on the truck, and the king pin. Thanks everyone for your info.
leveling, 255, sierra, f350
