Old 09-25-2016, 11:41 PM   #1
Leveling out between fifth wheel hitch rails
Hi y'all! new to posting, old on reading all of your great tips. I have a question regarding the fifth wheel hitch rails mounted in the truck bed. What have you done to fill the gap between the two rails in order to make the truck bed flat and useable. I have thought of a single piece of 3/4 plywood, but there would be a weak spot by the wheel wells and the notches in the wood for the rails. have you used two separate pieces of wood, or is there another solution. Thanks.
Rob and Linda
2016 Ram 2500 4x4 Diesel
2017 Sabre 330CK
Rob Haupt is offline   Reply With Quote
Old 09-26-2016, 12:04 AM   #2
SilhouettePenny's Avatar
We don't take the 5th hitch out of the truck bed. Just stack stuff around it and use a utility trailer to haul the sheet goods. If you install a single piece of plywood, be sure to secure it properly as the negative air pressure at highway speed will surely remove it and leave it in someone's windshield.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 09-26-2016, 09:50 AM   #3
NMWildcat's Avatar
Honestly the rails don't inhibit our bed use at all. Don't know what rails you have, but ours are smooth and low profile (no bolt heads sticking up). We do carry some moving blankets to put down if we are moving large items. If hauling sand/gravel we will put a tarp down to aide in easy cleanup. I would think trying to 'level' your bed would be more of a pita than dealing with the rails. True, it can difficult to slide in long, heavy items, but we just jump in the bed and lift over rails.
Scott and Liz - Southern NM
fifth wheel, hitch, leveling, wheel
