Old 09-03-2016, 07:07 PM   #11
Scott,
I don't know if I'm worry too much. Just want to hear from people with more experience. The idea is to travel perfectly level, right?
Hman0109 is offline   Reply With Quote
Old 09-03-2016, 07:33 PM   #12
CaptnJohn's Avatar
Originally Posted by Hman0109 View Post
Scott,
Yes but perfect only comes with luck. 1" will make no difference when towing as road differences will offset that
Old 09-03-2016, 07:36 PM   #13
NMWildcat's Avatar
Scott,
Well... I'm far from an expert on anything😀. We are on our 5th RV and 3 were level and the last 2 were both an inch high in front. I've always been told if you are within an inch of level, you are good to go. Hopefully others will chime in on this.
Scott and Liz - Southern NM
Old 09-04-2016, 01:32 PM   #14
You may be able to raise trailer pin ox by changing to different holes
Harkerr is offline   Reply With Quote
Old 09-04-2016, 05:12 PM   #15
Good point. Thanks
Old 09-04-2016, 05:13 PM   #16
Thanks Scott. Yes, it's only an inch.
Old 09-04-2016, 05:17 PM   #17
CANADA FROG RALLY 2017
B and B's Avatar
Originally Posted by NMWildcat View Post
I can't imagine that if the front is only one inch higher than the back that the load on your rear axle is affected that much. The equalizer for your tandem axles should take care of that. And to fix a one inch difference you only have to raise the back 1/2 an inch, or lower the front the same, which is hard to do as most adjustment holes on hitches are spaced one inch apart. Now if you had a 4 to 5 inch difference I can see where you would have a problem. But I guess the only way for you to be positive about axle load is to go to a scale.
Measure temperature after towing. If rear wheels are taking more load they will be hotter.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
fifth wheel, leveling, wheel
