Old 05-19-2016, 12:56 PM   #1
schrederman's Avatar
Lift kit for Torflex?
I posted this elsewhere and got no response...
My TT rides too low. It always has and this is not the result of damage. It's on Dexter Torflex 3500# axles. According to the tag they're #6 axles. I have been on Dexter's website and they seem to have these for #9 and #12 axles. I'd really like to stop dragging mine and so I need to lift it 3"... Anybody know which kit I need? Their instructions are pretty self-explanatory, so I'm not putting it off any longer. Unfortunately the website is a not real friendly as to an old computer unliterate curmudgeon's being able to figure this out.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 05-19-2016, 01:03 PM   #2
AquaMan's Avatar
You sure you're not reading that 6 upside down?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 05-19-2016, 01:06 PM   #3
AquaMan's Avatar
Did a little research, and I think your 3500 LB axles are #10, which covers axles from 2300lb-4000lb.
Old 05-19-2016, 01:08 PM   #4
AquaMan's Avatar
Here's what I was looking at.
http://l.b5z.net/i/u/6149609/f/Trail...nformation.pdf
Old 05-19-2016, 01:08 PM   #5
Call or email dexter with the numbers from the decals on your axle, they have exceptional support. The issue you can run into sometimes is they make runs of OEM specific axles for weight ratings. As an example my 2017 Roo has two #3000 Torflex axles per all the decals but in reality they are most likely exactly the same as the #3500's.
Mr Havercamp is offline   Reply With Quote
Old 05-19-2016, 01:17 PM   #6
Restcure's Avatar
Great to know as this is a high priority mod for us too. Where on the axle is the decal located?
Also - are Torflex and Al-Ko the same thing? I do know that Dexter owns Al-Ko now...
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 05-19-2016, 01:18 PM   #7
B and B's Avatar
I Have Dexter lift kits on my axles Bolt On. Installed at Goshen.
Old 05-19-2016, 01:23 PM   #8
Usually located right on the front of the axle tube. If its gone from use there is a stamped number on the tube, usually in the center and may be a little hard to find.
Not sure how they changed stuff around when they absorbed Kober.
Those lift kits are also dependent on how the axles were mounted and Dexter can help you determine that. When you get right down to it if you are or know someone handy with steel and a welder, making a lift for torsions is really easy no matter how they are mounted. Typically it involves only a piece of tube and some plate and being able to measure.
Old 05-19-2016, 01:35 PM   #9
I have a Windjammer with 4000 pound axles. When they built it the factory installed axles with the wrong mounting brackets so it rode low and actually rubbed the fender well. They replaced them with axles with a taller mounting bracket and a 2 inch square spacer. I now have 3.5 to 4 inches of clearance. Dexter recommended to me to have a minimum of 3 inches of clearance to allow for flexing.
Windjammin is offline   Reply With Quote
Old 05-19-2016, 03:38 PM   #10
Thanks, all... The axle number, if read with the rest of the print says #6. I've emailed Dexter twice and have no response, yet.
