Old 08-13-2013, 07:14 PM   #1
Camper Less Camping
Cajun Po-Boy's Avatar
Lippert New WD Hitch- Non Traditional Setup
Just read about his...called Strap Tek, it's a polyester strap & ratchet style mechanism...interesting new design!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is online now   Reply With Quote
Old 08-14-2013, 07:33 AM   #2
Seems like it could be great for hotshotters/delivery drivers.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
Old 08-14-2013, 08:49 AM   #3
avolnek's Avatar
Not quite sure how that would work... I'd like to see it in action... sure would be amazing not having to deal with the bars and such... frees up some space!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-14-2013, 01:52 PM   #4
might actually work for the aviator as the only one that does so now is the Blue Ox due to the front hood on the aviator lifts out and up making other brands not feasible , will have to look into it.
bob34787 is offline   Reply With Quote
Old 08-19-2013, 09:59 AM   #5
MtnGuy's Avatar
It appears to replace snap-up brackets and chains, but you would still need the current spring bars to attach to the Lippert system.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
Old 08-20-2013, 03:28 PM   #6
thebrakeman's Avatar
This simply replaces the chains and snap-up brackets on traditional WDH kits. You still use the same head and bars you already have. The marketing idea is that it's a lot of trouble raising and lowering the tongue jack "to get the right tension". Instead, you crank on these adjusters to lift the bars directly.
1. If cranking the jack ever gets too much for me, I (like many) will get an electring jack.
2. You only have to determine "the right tension" once, at initial setup. After that, you simply use the correct link in the chain. Or for those with an Equal-i-zer, there is zero guesswork.
3. Conversely, this new mechanism doesn't seem to have (?) anything that would let you know when you have pulled up on the bars enough. Do you have to measure the front wheel wells every time you attach the trailer?
Seems like a great solution to a non-problem.
thebrakeman is online now   Reply With Quote
Old 08-26-2013, 09:49 AM   #7
Incheon, S. Korea
BigBaron's Avatar
Polyester vs. Steel. UV rays don't hurt steel...
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 08-27-2013, 08:53 AM   #8
Let's not forget Lippert's reputation for 5th wheel frame and power tongue jack problems.
bwbarnes is offline   Reply With Quote
