Old 06-16-2015, 09:51 PM   #11
Originally Posted by thestrangebrew View Post
I just ordered the Airlift Loadlifter 5000 for my 2014 F150 EB. I'm hoping it'll compliment my Andersen WDH setup well.
You will probably need to adjust your Andersen after installing the Loadlifters. I ended up having to move the Anderson ball down two holes on the shank. I tried one hole for about a hundred miles and stopped change it. The trailer is now right at an inch lower in front than the rear when the nuts are tight.
madmaxmutt is offline   Reply With Quote
Old 06-16-2015, 10:03 PM   #12
thestrangebrew's Avatar
Thanks for the tip. Also, I cancelled my first order and ordered the Ultimate with the jouncers. I had assumed the 5000 also had the jouncers in them.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 06-16-2015, 11:29 PM   #13
Good choice. At least for me, the Ultimate adds a little peace of mind. I have read several threads over the years about people ruining a bag because of an air leak.
Old 06-17-2015, 09:02 AM   #14
Pauls Toy Hauler's Avatar
I just installed these a couple weeks ago. I've had them on another truck and they worked flawlessly. On my now truck though I did go with onboard air compressor with wireless remote and I have to say that is my favorite. especially with the presets. While I finish hooking up the fifth wheel I can just hit the preset and it does it's own thing. I also installed the Schrader valve as a backup in case the compressor craps out. This way I can fill it manually.
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
Old 06-17-2015, 09:12 AM   #15
I installed them on my 2008 Toyota Sequoia (similar to Tundra) and they have held up and performed well. The Sequoia has a relatively short wheelbase so it helped decrease porpoising when pulling the TT. Just keep in mind that they do not add any payload capacity to your TV, they just help by assisting/stiffening your stock rear suspension.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 06-17-2015, 10:47 PM   #16
Kash76's Avatar
Here is the review of them on my truck
http://keanen.com/blog/2014/09/11/ai...troller-review
Sent from my SM-N900V using Tapatalk
2013 Palomino SolAire 317BHSK w/Eclipse package using a ProPride 3P Hitch
2013 Ford F-150 Ruby Red SuperCrew 4x4 EcoBoost w/Max Tow, e-lock, Michelin LTX M/S2 tires, & Air Lift 5000 Ultimate w/Load Lifter
Campers: Me, DW, DD, DS
Nights camped: 2015 (4) as of 5/25 2014 (44) 2013 (26)
ProPride Review
Kash76 is offline   Reply With Quote
