Old 05-11-2016, 02:00 PM   #1
Location 5 gooseneck ball
Just installed a B & W Gooseneck hitch on my 2015 Chevy 2500 HD. To my surprise the ball is located 5.25" forward of the rear axle center. When we called B & W they said that is as it should be on that model. Besides making my 6.5' bed even shorter then expected (cab clearance) what other effects will the change have on handling?
Steve Ulman is offline   Reply With Quote
Old 05-11-2016, 08:34 PM   #2
Tfort's Avatar
It should make it handle better when pulling. That is further forward of the axle than mine but it kinda depends on the axle in relation to the rear of the truck. If the axle is set further back than you can afford it further in front of the axle.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 05-12-2016, 12:28 PM   #3
Makes the front axle take on some of the load... although not much with only 5-1/4" offset. This is usually a good thing.
Goosenecks generally don't have cab clearance issues, so that shouldn't matter.
325BH is offline   Reply With Quote
cat, location
