Old 07-08-2014, 04:06 PM   #1
Long or short bed truck?
I am shopping for a truck to pull the 5th wheel. A fellow RVer recommended getting a long bed truck. He claims that the long bed truck is more maneuverable with his 5th wheel and can make tighter turns. I honestly can't see what difference it would make. Can someone explain it to me??
joesmainship is offline   Reply With Quote
Old 07-08-2014, 04:10 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Welcome to the forum.
It all depends what kind of 5th wheel you are planning to pull.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 07-08-2014, 04:32 PM   #3
Ford Idaho's Avatar
I went with a long box because my truck hauls other stuff besides the trailer.
Never even thought about a short bed when I ordered it.
Only do over would be to have gone with a 1ton.
Old 07-08-2014, 09:03 PM   #4
Campin Cajun's Avatar
To answer your question, the longer bed truck keeps the nose of the %er further away from the cab of the truck. This allows you to be able to jack knife the RV. There are fifth wheel hitches made that slide backwards that will also allow you to do the same. Some fivers nose cap are made in such a way that will allow this also.
I had two fivers before I owned my current RV, I pulled both with a short be F250. I never had problems turning or backing into a site with my set ups.
My advice would be buy the truck you like the best or you will be buying twice.
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 07-08-2014, 09:36 PM   #5
WFD
With a short bed truck you will just have to be extra careful backing up so the nose of the trailer does not hit the rear of the cab...having said that...when you say long box....doesn't mean it has to be a full 8ft box. In 1/2 tons with a crew cab you will have about a 5 1/2 ft box but you can also opt for a 6 1/2 ft box...in the 3/4 ton lineup the 5 1/2 ft box is not an option and you will either get a 6 1/2 or 8ft box.....with my 6 1/2 ft box I have never had an issue...I also have a slider hitch but to date have never needed to use it.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-08-2014, 09:45 PM   #6
fast murray's Avatar
I'm on my 2nd short bed towing a 5th wheel and don't have a sliding hitch. I've yet to feel the need for one either. I may have considered a long bed if I didn't have to diagonal park in the street in front of my work but I've never had the need for one either.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 07-08-2014, 09:57 PM   #7
WFD
Is your short bed box a 5 1/2 or 6 1/2 ft box? Being that you are driving a 2500 according to your signature, sounds like a 6 1/2 ft box.
Old 07-08-2014, 09:59 PM   #8
If you get a 5er with the Reese Revolution, a short bed works great. No problem maneuvering the 5er and can go over 90° altho I don't know why you would want to.
Old 07-08-2014, 10:09 PM   #9
dcheatwood's Avatar
Many fivers are built now for shorter bed trucks and special pin boxes are available to move the pivot point rearward to prevent cab/RV contact on tight turns. There are some good videos online that show these products. One is Reese revolution.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-09-2014, 08:19 AM   #10
Thanks, everyone, for your replies. I really want to go with a quad cab and a short bed. Now I feel much better about doing so. Now I just have to decide what brand truck to buy, but don't wish to get into a discussion about that yet.
bed, truck
