Old 02-05-2016, 11:51 AM   #1
Camp Bartender
Looking at A new TV, these are the specs, anyone see a issue?
My wife and I are looking at a 2013 Dodge Ram 1500 Express, Quad cab. Has the 5.7L hemi in it, 24,000 miles. 3.55 Rear, can tow 8500. Our TT is a 2015 Wildwood 28DBUD.
29'10" Length
Dry Weight is 5900 lbs, tongue weight is 805 lbs. We have Reese load bars that are rated for 1250 lbs.
Our 2004 Avalanche with 3.73 a 5.3L gears and a max tow rating of 7200 lbs. This engine only had 295HP New
The 2013 Hemi has about 100 more hp and around 400 lbs of torque. Does anyone see any issues with that dodge pulling our TT?
Most trips are under 30 miles one way.
2017 Dodge Ram 1500 Big Horn, 5.7L HEMI
2015 Forest River Wildwood 28DBUD
2015-2018: 20 Trips, 61 Nights Camped
2018: TBD
stevensmith2859 is offline   Reply With Quote
Old 02-05-2016, 11:57 AM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Sounds good and more stable. Better than using the Avalanche. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 02-05-2016, 12:05 PM   #3
you need to look at your Payload. Rams are notorious for having low payload.
You won't max your ability to pull before you run out of payload
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 02-05-2016, 12:10 PM   #4
Camp Bartender
The max payload is 1700 LBS. I never really have much to put in the bed, but just want to be more confident on the road.....The avalanche makes my booty hole pucker at times, but it was also the "oh yeah, your Avalanche will have NO problem pulling this new camper that weighs 1000 more lbs dry than your trade in."
2018: TBD
Old 02-05-2016, 12:21 PM   #5
What does the sticker on the drivers door say?
IMHO, i doubt that you will find much difference between the pucker factor of these two trucks. Do you have passenger tires or 10ply on the Avalanche? what kind of tires does the truck have? that may make a big difference
Old 02-05-2016, 12:25 PM   #6
aceinspp's Avatar
Avalanche is shorter wheel base compared to the Ram. Pickup will definitely give you better handling. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 02-05-2016, 05:58 PM   #7
CWSWine's Avatar
Here is a website that will give you a estimate of what your truck can handle. Just enter the payload off you yellow sticker on your truck and take guess at the other weights.
Towing Calculator based on Truck's Payload/CCC - Towing Planner
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-05-2016, 08:41 PM   #8
Camp Bartender
The main thing is having the umph...the hemi has about 100 more HP and ft lbs of torque than the Avalanche.
2018: TBD
Old 02-05-2016, 08:49 PM   #9
davel1971's Avatar
don't forget, people are payload too. You might be closer than you think to limit
David & Lynn
Old 02-06-2016, 02:09 PM   #10
I think you will be fairly close on specs but ok. I pull a 23ikss hybrid with a 2013 Ram 5.7 hemi. Hybrid is 700 lbs dry lessthan yours with about 100 lbs less tongue weight. Pulls great. You should be fine.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is online now   Reply With Quote
