12-13-2017, 08:49 AM
Looking for any changes or tips for towing my camper
Hello Everyone,
does this look correct on my towing set up? This is my first toy hauler. We have a 10,000 lb equalizer WDH. Truck is a 2012 1/2 ton Silverado 6.2 gasser with 3.42 gears. The truck seems to have plenty of power. Any recommendations would be great. Truck does have a lift kit. But I had truck way before I bought the camper.
Dry Weight 5,030 lbs.Payload Capacity 2,745 lbs.GVWR 7,775 lbs.Hitch Weight 775 lbs.
Camper is a Grey Wolf 26RR 2017
12-13-2017, 09:08 AM
Follow these instructions (after you click Upload, wait until the upload is finished):
Originally Posted by Janet H
- Click reply and scroll down to bottom of text box.
- Click "go advanced" add text to message window and then scroll down.
- Click "Manage attachments" A separate window will pop up.
- Click "browse" Then select the file to be uploaded. Be sure that the photo is appropriately sized. 620 x 620 pixels (or smaller) and no more than 50K. Forums software will automatically reduce the size, but smaller size photos will upload much faster. You may select several photos to upload at the same time by repeating the last step.
- Click "Upload" After pics have loaded close the pop-up window
- Click "submit reply" to mount the text of your message - photos will automatically appear at the bottom of your post.
How to embed an image stored on another site:
You can do this by using image tags. Upload the image to a service like imageshack and then copy the URL of the image and put that between [IMG] tags. That will work well, as long as the host site stays in business and doesn't disable your image for overuse of bandwidth etc.
You can also paste in the location of a photo stored here in a photo gallery.
To do this: Paste the url of the image into your post. Then add the following code on either side of the url (with no extra spaces):
[IMG]url here[/IMG]
The image will appear where the url was in your text.
12-13-2017, 10:03 AM
Without knowing specifics or weights it looks "ok". The truck looks to be nose high. This could be a setup issue, you have a toyhauler (equals heavy TW till you load the back with a toy). If you have a toy back there and your are still nose high then it could be a problem. Also, what is your TW, 10K bars might not cut it, may need heavier bars to be effective. Post up your specs and weights and Im sure you'll get more specific answers, otherwise it is pure speculation.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
12-13-2017, 11:18 AM
As mentioned above, truck is nose high. Trailer appears very slightly nose low. I don't see a WDH installed. Based upon these observations:
1. Install a WDH
2. When installing a WDH, you will need to purchase a stinger that will allow you to drop the ball height since your trailer is nearly level and your truck is nose high. Most rule of thumb measurements for the ball height is around 1-1.5" higher than the trailer hitch measured when truck and trailer are not connected and on level ground.
3. After correctly installing and adjusting WDH, if your truck is still a little nose high, you might consider air bags. But there is a good chance that you can get everything level without air bags.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
12-13-2017, 11:33 AM
The Equalizer WDH hitch is installed on this pic.
12-13-2017, 11:42 AM
ok. I would suggest going through the Equalizer installation procedures again. Both the truck and the trailer should be level when adjusted properly.
2016 Microlite 21DS
Blue Ox SwayPro
12-13-2017, 12:10 PM
If that is your fully loaded towing setup you should lower the ball on the truck and put more tension on the WDH bars. Should bring everything back to level.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
12-13-2017, 01:06 PM
All the above. No question that an equalizer is called for. If installed, then it needs some adjustment.
12-13-2017, 03:02 PM
All good recommendations. That 6.2L will pull that but you are WAY nose high and will need to completely reconfigure the WDH to get that truck and trailer leveled properly. Once set up properly, it should tow like a dream. Just watch cross winds with a rig that long and the 1500. It will get exciting.
2015 Palomino SolAire 20RBS
2022 Silverado 2500HD LT Duramax 4WD
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days; 2019: 8 days; 2020: 0; 2021: 10 days.
12-13-2017, 03:59 PM
From the picture, you are way light on your front wheels. That configuration leads to a loss of steering control...
Check the instructions in your truck and hitch owner / installation manuals.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
12-13-2017, 04:35 PM
Originally Posted by mikegernes
Hello Everyone,
I have pretty much the same set up you have. Truck and trailer. All same weights and the same hitch. You definitely need to dial in the WDH a bit. There are lots of youtube videos on how to do this.
12-13-2017, 06:14 PM
Equalizer hitch video
I agree the front of your truck is too high and doesn't provide enough weight on the front tires which can be problematic in wind and any kind of slippery road surface. To get an idea of how to set up your equalizing hitch look at this video: How to Set Up a Weight Distribution Hitch - YouTube (copy of paste). This may help you get a more level weight distribution across the trailer and truck. Agree the the truck ball should be 1" - 1.5" higher than the trailer hitch when all sitting level on a flat surface.
12-13-2017, 06:51 PM
Casino Camper
Way too light in the loafers (front wheels of TV). I tow with a very similar vehicle and very similar trailer and mine sits completely flat but I did have to adjust the hitch a bit more than what they had set at the RV dealer.
After adjusting my hitch, I have 920lbs on the hitch of my GMC Sierra 1500 6.2L and I don't lift the truck nose more than an1/8 inch, you are looking at several inches like I was prior to adjustment. The truck is capable, the WDH is out of whack.
The 6.2L/6 speed only has issues towing 9200lbs (Cherokee 264L, fully loaded and 40 gallons of water or waste) on long 9% grades in 108 degree heat. I had to slow down and rev a little higher to keep the tranny below 220 degrees. I was fully loaded and at the end of a 400 mile drive in a mountain range so I expect most trucks would have been a little hot. My theory is that thee higher RPMs allow the tranny fluid to move faster and cool better.
I think the truck is full capable for vacations, however, it will take a beating if you try to full time cross country. I just did 2500 miles mostly mountainous driving in blistering hot weather and the truck did just fine.
2016 Cherokee 264L (Rear Living)
2013 GMC Sierra Denali
12-13-2017, 07:38 PM
No it does not look good. I suggest you add air bags to the truck. Air bags will level out the truck and help with weight distribution. I had to add air bags to my F250. The bags are not cheap at $700 plus depending on the options but they are worth every penny.
12-13-2017, 08:00 PM
Canadian Member
Hello Everyone,
Welcome to the forum, Mike. I agree with the other posters that it looks like the front of your 1500 is pointing up. When it’s like that, it’s not only light on the front axle which means reduced steering control but also your headlights may be aimed directly into the eyes of oncoming drivers. You definitely need to fix the setup.
You said the Equal-i-zer is installed in the picture. Did you have your toys loaded in the back of the trailer for that picture?
Those specs that you posted - are they the brochure specs for the Grey Wolf trailer? Brochure dry weights and tongue weights are notoriously inaccurate. Do you have your actual tongue weight once your toys are loaded? The 6.2L engine will be plenty powerful enough to pull your Grey Wolf. When fully loaded, are you within or not too much above your truck’s GVWR?
Also, since your truck has a lift kit you may need to buy another shank with a longer drop in order for the truck and trailer to both sit level. That’s assuming your Equal-i-zer and truck are sufficient for your trailer’s loaded weight. The Equal-i-zer website has a “find your shank size” calculator to tell you what drop you need for the shank. You’ll need to take 3 measurements that are explained on that page. Make sure you take the measurements with the truck unloaded on level ground, and the trailer coupler measurement with the trailer level (on level ground).
12-13-2017, 09:10 PM
Both should be a straight line if possible
12-17-2017, 09:27 AM
You mentioned you're lifted. Please say it's not a block lift. These lifts are notorious for throwing off the factory geometry causing handling problems with out a trailer. I would recommend never towing with a block lift.
Yes it is a little nose high. Adjust your WDH if possible. Maybe unlifting is the answer.
12-17-2017, 09:32 AM
I’m guessing you need a longer shank for your equalizer. I had the same issue with my truck. With the trailer level, and the hitch on the last hole of the shank, it was still 3” higher. Longer shank would be my first step.
12-17-2017, 09:42 AM
Hello Everyone,
From your Pic.your set up for "Coon Hunting" not Towing a RV! Longer/Lower shank and Start Again on the set up,Loaded as if "In Use"! Youroo!!
12-20-2017, 04:28 PM
jkoenig24
NO. The tow vehicle AND trailer should be LEVEL (or VERY close to level).
