Old 12-13-2017, 07:49 AM   #1
Looking for any changes or tips for towing my camper
Hello Everyone,
does this look correct on my towing set up? This is my first toy hauler. We have a 10,000 lb equalizer WDH. Truck is a 2012 1/2 ton Silverado 6.2 gasser with 3.42 gears. The truck seems to have plenty of power. Any recommendations would be great. Truck does have a lift kit. But I had truck way before I bought the camper.
Dry Weight 5,030 lbs.Payload Capacity 2,745 lbs.GVWR 7,775 lbs.Hitch Weight 775 lbs.
Camper is a Grey Wolf 26RR 2017
mikegernes is offline   Reply With Quote
Old 12-13-2017, 08:08 AM   #2
Mr. Dan's Avatar
Follow these instructions (after you click Upload, wait until the upload is finished):
Originally Posted by Janet H View Post
  • Click reply and scroll down to bottom of text box.
  • Click "go advanced" add text to message window and then scroll down.
  • Click "Manage attachments" A separate window will pop up.
  • Click "browse" Then select the file to be uploaded. Be sure that the photo is appropriately sized. 620 x 620 pixels (or smaller) and no more than 50K. Forums software will automatically reduce the size, but smaller size photos will upload much faster. You may select several photos to upload at the same time by repeating the last step.
  • Click "Upload" After pics have loaded close the pop-up window
  • Click "submit reply" to mount the text of your message - photos will automatically appear at the bottom of your post.
How to embed an image stored on another site:
You can do this by using image tags. Upload the image to a service like imageshack and then copy the URL of the image and put that between [IMG] tags. That will work well, as long as the host site stays in business and doesn't disable your image for overuse of bandwidth etc.
You can also paste in the location of a photo stored here in a photo gallery.
To do this: Paste the url of the image into your post. Then add the following code on either side of the url (with no extra spaces):
[IMG]url here[/IMG]
The image will appear where the url was in your text.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 70; booked = 24
Old 12-13-2017, 09:03 AM   #3
Without knowing specifics or weights it looks "ok". The truck looks to be nose high. This could be a setup issue, you have a toyhauler (equals heavy TW till you load the back with a toy). If you have a toy back there and your are still nose high then it could be a problem. Also, what is your TW, 10K bars might not cut it, may need heavier bars to be effective. Post up your specs and weights and Im sure you'll get more specific answers, otherwise it is pure speculation.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 12-13-2017, 10:18 AM   #4
As mentioned above, truck is nose high. Trailer appears very slightly nose low. I don't see a WDH installed. Based upon these observations:
1. Install a WDH
2. When installing a WDH, you will need to purchase a stinger that will allow you to drop the ball height since your trailer is nearly level and your truck is nose high. Most rule of thumb measurements for the ball height is around 1-1.5" higher than the trailer hitch measured when truck and trailer are not connected and on level ground.
3. After correctly installing and adjusting WDH, if your truck is still a little nose high, you might consider air bags. But there is a good chance that you can get everything level without air bags.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 12-13-2017, 10:33 AM   #5
The Equalizer WDH hitch is installed on this pic.
Old 12-13-2017, 10:42 AM   #6
ok. I would suggest going through the Equalizer installation procedures again. Both the truck and the trailer should be level when adjusted properly.
2016 Microlite 21DS
Blue Ox SwayPro
Old 12-13-2017, 11:10 AM   #7
If that is your fully loaded towing setup you should lower the ball on the truck and put more tension on the WDH bars. Should bring everything back to level.
2015 Sunseeker 3010DS
Cargo Pro all aluminum loaded with 1994 Goldwing Trike.
DougW is offline   Reply With Quote
Old 12-13-2017, 12:06 PM   #8
All the above. No question that an equalizer is called for. If installed, then it needs some adjustment.
JimMorrell is offline   Reply With Quote
Old 12-13-2017, 02:02 PM   #9
All good recommendations. That 6.2L will pull that but you are WAY nose high and will need to completely reconfigure the WDH to get that truck and trailer leveled properly. Once set up properly, it should tow like a dream. Just watch cross winds with a rig that long and the 1500. It will get exciting.
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 20 days (so far)
elchilero53 is offline   Reply With Quote
Old 12-13-2017, 02:59 PM   #10
SailorSam20500's Avatar
From the picture, you are way light on your front wheels. That configuration leads to a loss of steering control...
Check the instructions in your truck and hitch owner / installation manuals.
Al
Save the Earth. Itís the only planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
towing, camper
