Old 08-10-2016, 09:17 AM   #11
After reading a lot of reviews I chose the equal-i-zer. Haven been dissapointed. (Of course I haven't used anything else)
2008 Toyota Sequoia SR5 5.7L 10k tow package
2017 Rockwood 2702WS
Equal-i-zer 4 point, Prodigy 3 brake controller
2016 nights camped = 17
2017 nights camped = 4
Chpusmc is offline   Reply With Quote
Old 08-10-2016, 09:22 AM   #12
grhodes50's Avatar
I've used a 4 point Equalizer since '09 without any issues. It won't get rid of sway completely, but I've never experienced anything bad at all. Sometimes I feel a little of that being sucked over when semi's pass. Once it's properly set up, which isn't hard to do, it does a great job distributing the weight.
Just beware that it does make a lot of noise when you slowly pull into a campground. That's normal for these hitches. Might get you some looks from fellow campers, but I just smile and wave.
Gary & Trish
2018 Nights Camped - 5
Old 08-10-2016, 09:31 AM   #13
modemem's Avatar
Originally Posted by windsurfdog View Post
Consider the Blue Ox SwayPro...love mine.
SwayPro® | Blue Ox
Ditto
Forrest River,
2016 Wildwood,263BHXL
2013 F-150 STX 5.0 4X4
Heavy Duty Payload Pkg
Blue-Ox Sway Pro WDH
modemem is online now   Reply With Quote
Old 08-10-2016, 09:48 AM   #14
Coachman 312BHDS
tbln930's Avatar
Interesting posts. I see no sway whatsoever (I can't even make it sway) but my dealer just told me the wide axle stance on our 312BHDS 37' is partially responsible. That might be a consideration on a TT purchase besides just the WDH.
2017 Open Range Roamer RF376FBH 42' fifth wheel
2016 F-350 Lariat SCrew 6.7L Turbo Diesel SRW - Extang Fold-up Hard tonneau cover - Husky 16k Fifth Wheel Hitch
tbln930 is offline   Reply With Quote
Old 08-10-2016, 09:59 AM   #15
Originally Posted by stantyszka View Post
I see a lot of them on the road. Can you point out advantages of it over the fastway e2? I've not towed with anything other than the hitch I was sold when I bought the trailer last year. Still a little new at this
I used a 4-point equalizer on our 30' TRAVEL TRAILER and it worked great. The difference between the 2 point and 4 point is that the 4 point also has built in sway control along with weight distribution (WD). Your 2 point only has WD..
Do you have sway issues? If no,maybe it's a moot point.
Go to Equalizers home page and check it out..
4-point Sway Control
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-10-2016, 12:30 PM   #16
Some guy in back...
Think about cost, time to hitch/unhitch, storage of parts, weight of hitch, complexity of hitch and how well your current vehicle tows your trailer with whatever you use now.
Some variables: actual weight of TV, tongue weight of trailer, air pressure in TV and trailer tires and all the variables in the tires themselves (sidewall stiffness, age, tread, construction (to name a few)
Also remember there are two things you want to accomplish: weight distribution and correcting/controlling trailer sway.
Everyone towing has their own experience. Few have a wide range of experience and very few have a rig (TV & trailer) that is the same as yours. Be critical of
every recommendation and always decide for yourself.
There are MANY hitches to choose from. A case can be made for each one. The best hitches (Hensley & ProPride) are expensive, heavy and can take some time to get used to. I've towed with a Hensley and can confirm it is a superb hitch. I currently tow with a semi-generic WD hitch from Reese and it works surprisingly well. YMMV
Bottom line: If what you have works, you can spend more money and you may experience a change (good or bad). If what you have now is not working for you, read the manual, understand what it says and confirm your hitch is set up correctly. Work with a real-live hitch shop (not the average RV dealer) if you need help. After that, you pay your money and you take your chances.
Cheers
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 08-10-2016, 12:54 PM   #17
Coachman 312BHDS
tbln930's Avatar
I know a couple that absolutely loves their ProPride 3P and another couple trying to get rid of their Hensley Arrow. They said there are a lot of used Arrows on the market.
Old 08-10-2016, 12:56 PM   #18
The 2-point has sway control according to this: https://www.etrailer.com/Weight-Dist...4-00-1000.html
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 08-10-2016, 02:02 PM   #19
I've used two different capacity Equalizer 4 ways, a Blue Ox Swaypro with two different capacity bars, and an Andersen, all with the same trailer and tow vehicle and sometimes more than one on the same trip. I highly recommend the Equalizer. Best combination of ease of use, neutral handling and elimination of sway.
hunterrick is offline   Reply With Quote
Old 08-10-2016, 02:24 PM   #20
Sham183
You tube some videos of weight distribution hitches and look also at Etrailers they have really good info and reviews. Make a informed decision that you think best suits you. The other thing you could do is next time you go to a CG ask around and see what people have and see how they like it and if they have any issues. I did this and it was very helpful for me.
Good luck
Tim
mopwr4me2003 is offline   Reply With Quote
hitch
