Old 08-12-2016, 11:05 AM   #41
Coachman 312BHDS
tbln930's Avatar
That is exactly what they said. Hooking it up is a royal pain.
2017 Open Range Roamer RF376FBH 42' fifth wheel
2016 F-350 Lariat SCrew 6.7L Turbo Diesel SRW - Extang Fold-up Hard tonneau cover - Husky 16k Fifth Wheel Hitch
tbln930 is offline   Reply With Quote
Old 08-12-2016, 12:24 PM   #42
I watched a fella hook up to one of those hitches next to me one day. First off the hitch was a brute and just glancing at it I thought there was an awful lot to line up.
I was right.. He and the DW took about a 15-20 minutes min getting it to line up and how his trailer was sitting he actually had to put blocks under the TV tires to get the right angle.
He swore by it though and probably good thing he had it. He was pulling about a 43' trailer behind an F250 short bed gasser that he had loaded to the kilt.
Old 08-12-2016, 05:40 PM   #43
Exlimey's Avatar
Originally Posted by Stormrider151 View Post
Try bearing grease on the ball and trunion bar pivot points. Mine was noisy till I tried that. I get an occasional pop but that's it.
Thanks for the tip. I put grease on the trunnions bar pivot points and I didn't get the usual obnoxious popping when I'd make a turn. No more embarrassment when I pull into the campground and camp site!
Neil and Kimberli
2016 Silverado Z71 double cab
2016 Flagstaff 29KSWS Super Lite
Exlimey is offline   Reply With Quote
hitch
