Old 04-19-2016, 04:55 PM   #11
2007 WildCat 32QBBS
05CrewDually's Avatar
What year is this truck?
05CrewDually is offline   Reply With Quote
Old 04-19-2016, 06:43 PM   #12
Mmnsc's Avatar
Truck is a 2002. As soon as I get a chance I will have to take the truck to a Ford dealer to do a check of the electrical system. This has me really stumped.
Mmnsc is offline   Reply With Quote
Old 04-19-2016, 07:06 PM   #13
2007 WildCat 32QBBS
After reading through and you claim there is 9v @ the taillight bulb terminal I'm suspecting bad headlight switch. Also if during the testing you only had 9 volt at the chassis harness then you need to keep looking at the harness until it enters the cab. If all looks well, next I'd check the headlight switch. Over time the contacts in the switch get dry and form a film of corrosion causing resistance which will show as low voltage with everything on.
If you want to double check the trailer plug, lay under the truck look up at the plug. The harness will unplug @ the backside of the 7 blade plug. Then follow the harness towards the driver's side frame rail. There you should find another plug. Unplug BOTH of these and inspect the harness and the teminals inside. If they're green go to the dealer and get a new one.
While it's apart, use a meter and see if you have full battery voltage at one of the terminals with the parking lights on. If you do have good voltage now then the problem lies in that pigtail you removed.
An older truck like that and without seeing it myself, I'd suggest replacing the plug and pigtail harness.
Old 04-19-2016, 07:20 PM   #14
Mmnsc's Avatar
05crew
Thanks for the suggestion of the pigtail. I would never have thought of that. As soon as I get back from this trip I will definitely check that out and if that is okay next look at the headlight switch.
Old 04-19-2016, 07:45 PM   #15
2007 WildCat 32QBBS
As you can see there's multiple connections to check for corrosion.
One other thing to consider to check are the ground connections.
You can find new components here https://www.amazon.com/dp/B001GBJQCA..._MdTfxb0PVNDE6
Old 05-06-2016, 06:11 PM   #16
2007 WildCat 32QBBS
Mmnsc............ was this ever solved?
Old 05-06-2016, 06:21 PM   #17
Mmnsc's Avatar
Yes I finally found out what was going on. Who would believe that the trailer tail light connector would have a separate fuse from the regular tail lights even though they both come on when you turn on the lights. There is a separate fuse under the hood in the power distribution box for just the tail lights on the trailer connector.
I wasted a whole day trying to track down a simple blown fuse. The weird voltage I was getting at the plug must have been feed back from the normal tail light.
Thanks for asking.
light, trailer, voltage
