Old 10-07-2010, 06:45 PM   #1
LT tire pressure
I have Load E 80 Pound max PSI tires. The manual states you don't get the full Load E rating unless you inflate to 80 PSI.
Any recommendations on how I should go about calculating the right PSI? What are others using????
While not towing I have 65 lbs in front and rear. Since the whole idea of a WDH is to split the weight between both axles, should I keep the same pressure equal while towing?
Arizona Garry and Bobbi
2011 Rockwood 2604SS
2006 Ford F150 4x4
Arizona Garry is offline   Reply With Quote
