Old 08-25-2015, 04:38 PM   #11
Big Rig's Avatar
I researched replacement tires for my 08 1500 Silverado and I had decided on General Grabbers. They had some great reviews and pricing. Ended up trading it in before I bought them. Bought a 3500 Denali instead and already hate the Michelins it came with, very poor traction in the wet.
Big Rig is offline   Reply With Quote
Old 08-25-2015, 09:11 PM   #12
beerjay's Avatar
Originally Posted by howie70 View Post
beerjay, I have checked the Michelin's since we run them here at work. For whatever reason, they do not have an E, D or even XL in the LTX A/T2 in my 275/60/20 size.
Matter of fact, their standard load tire in that size is around 2350#. The standard load I am running now is 2601#.
Seems like its a different model.
Here is the Costco page. For my tires. LR E 80 psi. 3195 lbs at 80 psi
Costco.ca: Shop for Tires
2009 Suburban LT 1500 - 4x4 - 3.42
2009 Flagstaff 23FBS Super Lite
Nights Camped in 2015 - 21
Nights Camped in 2014 - 29
Nights Camped in 2013 - 31
beerjay is offline   Reply With Quote
Old 08-25-2015, 09:14 PM   #13
That is part of my issue beerjay, there is next to nothing to choose from in my stock size. I can't go bigger. Could go smaller. I am even having a hard time justifying E or D rated tires. I have pretty much decided against them. I have towed with P rated tires on my current truck for the past 4 years with zero issues. I have only found the 1 tire in my size in an all terrain LT tire and it is a D rated tire.$1150
I can get the Cooper AT3 in P for $780.
We are weekend warrior campers who doesn't venture far from home. 6 trips this year ad it will be less than 700 miles total with a 4500# camper. As I said, hard to justify the price difference while towing that little.
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 08-26-2015, 05:53 PM   #14
beerjay's Avatar
Sounds like you have looked at the options. My tires are standard. People need to watch the special edition TVs tires for example the 20 inch tires and other options reduce tow capacity (load range) if you look at the manufacturer tow specs and will allow the rim to dent if you hit a bad pot hole. (We have potholes in Canada that are given an area code ...)
I don't tow a lot but I use the SUV mostly for towing, I can wait months to fill it in the winter. So after the P tires were done I went to LT tires. It is peace of mind and as in my experience it is much more fun to tow now. If you search here you will see many regulars who have commented on tire choices and picked LT.
tire, tires
