Old 08-22-2015, 06:16 PM   #1
DF5.4's Avatar
LT Tires
My truck is factory rated to tow 9000 lbs. My camper is (estimated) about 7000 lbs. the TV originally came with P rated tires. When I towed I would air them up to max (50 psi). It towed ok but I still had some white knuckle moments on the interstate when tractor trailers and busses would pass me. The first time I replaced the tires I put the AT tires on but stayed with the P rated. No change in towing but I didn't expect any. Earlier this year I replaced the tires with Another set of ATs. This time I went with LTs (E rated). I run them at 37psi for normal running around. I think the truck handles better with them. No more soft, squirmy feeling. I knew they would feel better towing but I didn't expect it to feel this much better. I don't understand why, when a truck has a HD tow package they don't put the right tires on it.
If anyone needs to replace tires I will tell them to spend the extra for LTs. Even on 1/2 ton and SUV TVs. They don't ride any worse empty and they tow that much better than P rated tires.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 08-23-2015, 07:21 PM   #2
I agree owning a 2011 f150 pulling my vibe @7012 lbs empty when trucks passed I was wiggling like a snake just installed a hell wig rear sway bar and nitto 285/65/r18 e rated tires and what a difference.
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 08-24-2015, 12:01 PM   #3
beerjay's Avatar
I did the same thing with my Suburban earlier this summer.
I made a similar post as you did about the amazing improvement in towing a few weeks ago. The Michelin LTX tires I got are also highly rated for snow and rain traction. The ride is a little rougher and I need to get my TPI monitor adjusted up from the factory 30psi default.
No more riding on P tire balloons...
2009 Suburban LT 1500 - 4x4 - 3.42
2009 Flagstaff 23FBS Super Lite
Nights Camped in 2015 - 21
Nights Camped in 2014 - 29
Nights Camped in 2013 - 31
beerjay is offline   Reply With Quote
Old 08-24-2015, 12:13 PM   #4
I need tires and have been researching this to no end. Even started a thread on it myself. I want an All Terrain tire and can only find a D rated (BF Goodrich TA KO2) tire in my size in an All Terrain LT. 275/60/20
I am not pulling near as much weight as you- 4100# dry. I realize that number goes up with the camper and truck loaded, but so far I have had no issues with P rated tires and am debating if it is worth the cost difference to go to the D's.
If you don't mind me asking, what tire did you get? (brand/model)
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 08-24-2015, 01:43 PM   #5
beerjay's Avatar
I got Michelin LTX M/S2 tires LR E max 80psi. LT265/70/17 for the Suburban. 115,000 km warranty (70,000 miles). Can't beat the Costco price and $15 installation. Lifetime rotation, balancing, and road hazard including nitrogen fill. They are filled to 45psi to match the load rating required. So that sets off my TPI monitor. Need to get it reset.
PS They also have an LTX A/T2 tire that is more aggressive for gravel and off road and is well rated.
Old 08-24-2015, 02:10 PM   #6
beerjay, I have checked the Michelin's since we run them here at work. For whatever reason, they do not have an E, D or even XL in the LTX A/T2 in my 275/60/20 size.
Matter of fact, their standard load tire in that size is around 2350#. The standard load I am running now is 2601#.
2016 Flagstaff 23LB
Old 08-24-2015, 05:24 PM   #7
DF5.4's Avatar
I have Mastercraft Courser LTR. LT 265/70-17. There is a place locally I trust and this is what they recommended for me. So far I have no complaints with these tires.
Doug
Old 08-25-2015, 11:06 AM   #8
I am running those on my 2013 F150 and really like them.
Old 08-25-2015, 03:33 PM   #9
ARLO
I always go to E rated 10 ply tires when the P's need to be replaced. It's like night and day.I also replace the underrated OEM trailer tires with E/10 plys.
rlocicero is offline   Reply With Quote
Old 08-25-2015, 03:53 PM   #10
rsdata's Avatar
what he said...
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
tire, tires
