Old 03-21-2019, 12:26 PM   #1
LT tires vs P-Metric for towing?
I know this has probably been asked and answered many times.... I'm towing a 37' Lacrosse with a soon to be 2019 F150. Trying to decide whether LT tirres or P-Metirc provide better handling while towing. Looking for less sway. Yes, I have an Equal-i-zer hitch, and I don't want comments on the weight of the trailer and that I should be driving a F250.... Heard all that already. It does just fine, but would like to reduce the sway on the highway.
canmes is offline   Reply With Quote
Old 03-21-2019, 12:29 PM   #2
Wow thats a big unit for a 150 i know you don't want to hear it but if it does just fine then why ask? seems you need a Hensley $3000.00 hitch or you will die
MR.M is offline   Reply With Quote
Old 03-21-2019, 12:42 PM   #3
llr
I had a similar size TT with my F150 and the LTs helped, but not nearly enough, went to a 3/4 ton.
I am confused, you say a soon to be F150 and it does well with the trailer. If you don't have the truck how can you know? Good luck.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is online now   Reply With Quote
Old 03-21-2019, 12:45 PM   #4
MT Biker's Avatar
LT tires will tow much nicer but your ride quality when driving the truck empty will suffer.
https://www.facebook.com/westshorerailway/
2019 Ford F-250 Super Cab 6.2L Lariat
2016 ML23FB
MT Biker is online now   Reply With Quote
Old 03-21-2019, 12:50 PM   #5
bikendan's Avatar
For that size of TT, NO way would I tow it with Pmetric tires.
I tow with a F150 EcoBoost. So I'll just say, Good Luck to you.
Equalizer WDH
Old 03-21-2019, 01:02 PM   #6
35TwinTurbo's Avatar
Base on what your towing you should go with LT rated tires load E range..replacing my P-rated tires that came with my 2011 f150 EB is the best decision i made..towing are 5th wheel rockwood greatly improve the handling
35TwinTurbo is offline   Reply With Quote
Old 03-21-2019, 01:30 PM   #7
LT tires, LRD or LRE would be best. Avoid aggressive tread for more contact area and less squirm. Don't grease anything on the hitch. Increased friction results in less sway. You'll likely have porpoising- Airbags with stiffer rear shocks- I prefer the Rancho RS9000XL on the highest setting-will solve that.
Old 03-21-2019, 02:19 PM   #8
D W
D W's Avatar
I picked up on that, too. Confusing... Apparently it does not do well as you have sway.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 03-21-2019, 02:35 PM   #9
Semperfi24's Avatar
My interpretation is that he is towing with an F150 (undisclosed model year), and he is purchasing a 2019 F150. So the truck/trailer combo is the same, just that he is upgrading to a new truck (of the same model). I could be wrong, but thats how I read it.
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is online now   Reply With Quote
Old 03-21-2019, 02:49 PM   #10
rsdata's Avatar
You air them up to tow, then let some air out to drive without towing... not that big a deal about ride quality...
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
tire, tires, towing
