Old 03-02-2014, 07:19 PM   #11
avolnek's Avatar
Originally Posted by youroo View Post
Vaseline on your balls is a clean lube to apply and easy to wipe off after use. Wheel bearing grease or Anti-sieze is very hard to remove after use! Vaseline applied to Dual cams lessens wear also! Youroo!!
I'm not a fan of vasoline because it thins too much when put under pressure. I'm not against it as it is better than nothing!
I would feel better with vasoline if doing it like I feel people have mentioned here and cleaning it all off when not in use an then re applying new when towing.
The negative comments I have heard about "lubing" is the line will attract dust and rocks and cause more wear than if the ball were left dry. I personally don't agree with with this and am a firm believer of wiping the ball and coupler when not hooked up and re applying fresh for my hour long or longer trips.
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 03-02-2014, 07:32 PM   #12
I use the same lube I use on my Equal-I-zer hitch. When not hooked up, I've got one of those rubber covers. Take off the trailer, put on the rubber cover, put the entire WDH in a large plastic bin with a cover. Ready to hook up, put the hitch in the receiver, take off the rubber cover and throw it back in the plastic bin. Everything stays nice and clean. You don't need a lot on the ball. Just a little to keep it slippery.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 03-03-2014, 07:02 AM   #13
Wanna Be Camper
SaskCampers's Avatar
Just remember if you happen to live in the country on dirt roads like us, if you grease the ball with anything it collects all kinds of fine particle material then the grease with it's new found material acts like very fine emery cloth and there will be no chrome left on the ball. Ask me how I discovered that little tidbit.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-03-2014, 07:16 AM   #14
I use a thin coat of Reese Teflon hitch lube. I remove the hitch from truck when not in use to keep dirt away and clean with brake cleaner at least once a year depending on my travel miles. chrome still looks good
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 03-13-2014, 09:21 AM   #15
Perma-Newb
I use the reese lube, it’s no more expensive than anything else. I lube the ball and all 4 contact points of my equalizer hitch. Makes for a much quieter and smoother turning rig.
2015 F350 Dually, 6.7 PSD
2014 V-Lite 30WIKSS, Diamond Package W/All the goodies
http://www.forestriverforums.com/attachments/signaturepics/sigpic50858_1.gif
EarlyRetirement is offline   Reply With Quote
Old 03-13-2014, 09:35 AM   #16
N3HCP's Avatar
With our Clipper I also use Reese Teflon hitch lube. I put a thin coat on the ball before every trip and wipe off the ball and inside the hitch when I unhook. Only takes a couple of seconds and I'm still on the same container of lube I started out with many years ago.
2013 F-350 Diesel Dually, 6.7L with 3.73 rear with 50 gallon Transfer Flow aux fuel tank, ScanGauge II, Tire Minder on all 10 tires, 2M ham radio, and the ever popular CB.
2014 Surveyor SVF-293RLTS
2014 Clipper 16FB
N3HCP is offline   Reply With Quote
Old 03-13-2014, 10:02 AM   #17
^^^This. I use white lithium grease and a rubber ball cover.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 03-16-2014, 12:36 AM   #18
KB3MMX's Avatar
I've used the Amsoil MP HD dry lubricant for years with great success. It isn't messy like grease and it keeps the hitch from rusting.
-Forest River Sierra 355QBQ Bunkhouse
-2007 Duramax/Allison Stage 2 Garrett Turbo W/ KB3MMX EFIlive custom tuning & lots of other goodies...
KB3MMX is offline   Reply With Quote
Old 03-16-2014, 03:37 AM   #19
Engineer of Crazy Train
ChooChooMan74's Avatar
I need to try that. I hate grease! My legs hate it more!
Sent from my Samsung Note 8 Tablet using the FRF Android App!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-16-2014, 06:22 AM   #20
rattleNsmoke's Avatar
When we owned our Jayco TT, always used white lithium grease on the ball and BARELY used any lube on the weight distribution bars, perhaps a drop or two of oil. I was told by a tech years ago the bar ends should be lubed by a few drops of oil and that's all due to the fact that you want the friction to work with you keeping the trailer stabile and difficult to sway especially when being passed by a semi at highway speeds. Although the trailer did sound like a sinking ship, moaning and groaning when turning tightly, I did notice more stability when testing this lube theory myself.
rattleNsmoke is offline   Reply With Quote
hitch
