Old 08-25-2016, 05:20 PM   #31
Never, it is a grounding point for your electric, I'd rather deal with a little noise.
2015 Tacer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
http://www.visitedstatesmap.com/imag...AWAWVWYmed.jpg
SilverArrowPro is offline   Reply With Quote
Old 08-25-2016, 06:10 PM   #32
I use silicone spray on the ball, inside the hitch and on the sway bar balls. Seems to work for me. I have used some really ugly black high pressure stuff but I can't tell the difference.
DoggieDaddy is offline   Reply With Quote
Old 08-25-2016, 06:49 PM   #33
Tiltin Hilton
SilverArrowPro-Back in the old days we had 3 wire trailer wiring, left-right-stop, ground through hitch ball. This worked OK because the ball was bolted to a Barden type steel bumper with steel brackets to the steel frame of tow vehicle. Then receiver type hitches became the norm, but with a painted shank and the slop in the receiver, the ground was no good. Now 4 wire trailer wiring is the minimum, and 7 way is pretty much now standard on large trailers. Do lube your ball. Metal to metal will wear out coupler and ball. If you still run 3 wire, add a good ground wire.
drmoparPHD is offline   Reply With Quote
Old 08-25-2016, 07:32 PM   #34
Originally Posted by drmoparPHD View Post
I think we have all run into the hitch at one time. With my hitch, and after cleaning and lubing the 2 5/16" ball, I cut the bottom off of a "Aquafina" 16.9 plastic water bottle with the white cap still on. It fits snug, stays on at highway speeds when not towing, keeps everything clean, and with the white cap I can see it before I run into it.
That's exactly what I do. Except, I use the bottom of the bottle inverted and it is held on with a strong magnet!
ornery is offline   Reply With Quote
Old 08-25-2016, 07:32 PM   #35
@drmoparPHD thanks for the update. Running 7 wire, so maybe I'll try a little dab.
Old 08-25-2016, 08:25 PM   #36
raspivey's Avatar
Yes, you've got a separate ground in the wiring harness. A little grease won't hurt you at all.
2012 Chevy Tahoe LTZ - HD tow package
Old 08-25-2016, 08:37 PM   #37
Vaseline! Youroo!!
Old 08-25-2016, 09:18 PM   #38
You all are geniuses! Campers are creative people. Thanks for all the ideas.
RevKen is offline   Reply With Quote
Old 08-25-2016, 09:34 PM   #39
We use Lithium grease. Keeps things quiet and makes hooking up/unhooking easier.
John Spear
RMCS (SW) USN Retired
2012 Ford F-150
Rockwood 2503s
debandi is offline   Reply With Quote
Old 08-25-2016, 09:47 PM   #40
Oaklevel's Avatar
and...........many use no grease
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
hitch
